MORE vibration over 40mph - JeepForum.com
post #1 of 10 Old 02-24-2006, 10:10 AM Thread Starter
Lenen98
Okay, to start off, I'm no mechanic, but I try, so bear with me....
I have a '97 cherokee, 4WD, manual, about 90K miles...
I'm having the much talked about front vibration problems, starts at about 40mph and gets worse the faster you go. It felt exactly like a tire that was badly out of balance, so I put my other set of wheels and tires on, no change at all.
I just replaced the front U-joints this past summer. I checked them anyays, feel okay.
I though it was bearings, so I jacked up the front end and tried shaking the wheels, no unusual movement, at least not that I could tell.
I read about the front drive shaft, going to the front differential, so I tried shaking that, it doesn't move up and down or end to end. It can rotate slightly, but I think that is normal.
I tried the "putting it in neutral at highway speed and turning it off" method, it still does the same thing.
SO, any thoughts? Might it be bearings, even though there is no excessive movement? Any other clues? Any help would be appreciated, I don't want to walk into a repair shop blind. Thanks!
Lenen98 is offline
post #2 of 10 Old 02-24-2006, 10:15 AM
LEAD_NOT_FOLLOW
LEAD_NOT_FOLLOW's Avatar
1989 XJ Cherokee
Welcome to Death Wobble (DW).
First thing I would do is get an alignment. They at that time will be able to tell you if anything else is wrong with the front end. Also make sure everything is tight upfront.
LEAD_NOT_FOLLOW is offline
post #3 of 10 Old 02-24-2006, 02:06 PM
Thayer
Shouldn't write MORE when you mean More because I thought you meant Mountain Off-Road Enterprises.
1997 Cherokee Sport NAXJA #1255
RK 4.5" LA Kit
Thayer is offline
post #4 of 10 Old 02-24-2006, 02:16 PM
woodstock01
Is it stock height or lifted? If lifted I have a 1" TC drop kit from Rusty's I didn't need. I started to round out the holes a bit but never installed it. Cost $20 + shipping from Rusty's I'll do $15 shipped. You'll need 1 more bolt for it though, one got stripped from the kit. I think it's about $2. Just something to think about if you have a lift.
Jason
woodstock01 is offline
post #5 of 10 Old 02-24-2006, 02:33 PM
XJ4oh
1997 XJ Cherokee
I 2nd getting an alignment. Ive been told you can also pull the front driveshaft off, it can be out of balance even though it might not look like it... But if you pull it and the vibes go away then theres your issue. I would start out with an alignment first though.
'97 XJ... 4.0 4x4 AW4. 2" budget boost w/t-case drop.
31x10.5 Cooper Discoverer ST's on 15x7 Cragar Soft 8's.
Intake, Ported TB, TB spacer, Super 40 Flowmaster.
Baja Aux. Lighting.
Green Jeep Club #185, Nowhere to Wheel Jeep Club member #1
'04 WJ - Columbia Edition - 4.7HO 2WD
XJ4oh is offline
post #6 of 10 Old 02-24-2006, 02:37 PM
conrasm
conrasm's Avatar
My death wobble started around 45 mph. Went away after an alignment.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
post #7 of 10 Old 02-24-2006, 02:48 PM
StokedXJ11
1997 XJ Cherokee
I also got mine aligned and it was fixed...
Stock 1997 Jeep XJ Country
RJC #377
StokedXJ11 is offline
post #8 of 10 Old 02-24-2006, 03:13 PM
FitchVA
Jeeper 4 Life
FitchVA's Avatar
wait...i thought death wobble was when you hit a bump and it would cause your front end to shake left and right uncontrollably.
it sounds like you have a driveline vibration of some sorts.
i'd try removing the front driveshaft and see if it still does it. if it does, you can rule that out.
then recheck everything like your tires, ujoints, and hubs again.
it could be anything from a tire weight getting thrown off, the tire itself getting out of round, same for the wheel, bad alignment, etc.
you need to check each one.
'98 xj sport (trail toy) |
'98 xj classic (dd'er) |
'89 mj tinker toy |
FitchVA is offline
post #9 of 10 Old 02-24-2006, 03:19 PM
dynamite44
i'd suggest a bent rim or a tire missing a weight.
2000 XJ silverstone metallic.
dynamite44 is offline
post #10 of 10 Old 02-27-2006, 08:56 AM Thread Starter
Lenen98
Thanks, I'll have to try pulling the front drive shaft, and get an alignment, I'm almost positive it's never had an alignment.
To reply to other posts, it is all stock, except for shocks, and slightly larger tires.
It's not tires or wheels, I have two sets of tires and wheels, and they both feel the exact same.
Lenen98 is offline
2.5L cuts out after 40mph tx81jeep XJ Cherokee Technical Forum 0 05-31-2009 04:08 PM
Cruise control doesnt work under 40mph? Motorvated XJ Cherokee Technical Forum 6 06-19-2007 12:07 PM
wont run good past 40mph? damage inc. XJ Cherokee Technical Forum 5 03-15-2007 10:41 AM
wont run good past 40mph? damage inc. XJ Cherokee Technical Forum 6 02-23-2007 12:07 PM
Jeep is confused at 35-40mph. titus95 XJ Cherokee Technical Forum 8 02-21-2003 04:54 PM
