Mirror Help - JeepForum.com
post #1 of 8 Old 01-27-2011, 09:05 AM Thread Starter
D0dgeRam1500
Mirror Help
I woke up today to find a tree on top of the front of my XJ. I was wondering since the tree also took out my driver's side mirror if I can get 97+ mirrors and get them to work on my 90 XJ. If any of you have done this or if there is a write up on it I would really appreciate it.
2005 Jeep Wrangler Willys Edition
D0dgeRam1500 is online now
post #2 of 8 Old 01-27-2011, 10:01 AM
ChicoXJ
1986 XJ Cherokee
Yes you can.
ChicoXJ is offline
post #3 of 8 Old 01-27-2011, 11:58 AM Thread Starter
D0dgeRam1500
Does it just plug in or do I have to splice some wires?
post #4 of 8 Old 01-27-2011, 12:00 PM
Yucca-man
If they are power mirrors, I believe there's some minor splicing. Otherwise, the newer mirrors are nearly bolt-in replacements. I believe you might have some minor interference with a little trim that should be removed - there are a few writeups floating around. I'll see if I can find my favorite again
Yucca-man is offline
post #5 of 8 Old 01-27-2011, 12:02 PM
Yucca-man
Check out http://go.jeep-xj.info/HowtoMirrors.htm - the main part of his writeup involves just changing out the mirror, but does show a few shots of the 97+ mirrors on another Jeep.
post #6 of 8 Old 01-28-2011, 12:19 AM Thread Starter
D0dgeRam1500
I read the article and it bolts right on but doesn't say anything about wiring it when you already have power mirrors. I would like some sort of diagram if anyone has one.
post #7 of 8 Old 01-28-2011, 12:45 AM
Yucca-man
Ack. Looking at it again, you're right. Sorry about that, I just glanced over it and thought that's the one I referenced a few years back. Not sure where I saw the wiring bit now...
post #8 of 8 Old 01-28-2011, 06:02 AM Thread Starter
D0dgeRam1500
Mine is power and not heated and if I order the 97+ that are power and not heated, will I have the same amount of wires? If so, should I be able to play with the wires until the correct motion on the switch is matched with the correct motion on the mirror?
1990 , cherokee , jeep , limited , xj
mirror spring?? olebluejeep XJ Cherokee Technical Forum 2 08-05-2010 09:34 PM
P-Side Mirror Krautzy XJ Cherokee Technical Forum 5 08-22-2009 08:45 AM
mirror years 3fifty XJ Cherokee Technical Forum 6 03-05-2008 09:26 PM
Broken 99 XJ LH mirror '99RedXJ XJ Cherokee Technical Forum 2 01-09-2006 09:44 AM
Mirror help lma1973 XJ Cherokee Technical Forum 5 05-28-2004 04:57 PM
