Quantcast Mini Spool For Dana 30??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Mini Spool For Dana 30???
Old 01-15-2009, 03:52 PM   #1
SILASPRIT
i have a vacuum actuated dana 30 and im going to get the posi lock. Can i get a mini spool for the dana 30 sence i have a axle disconnect and still have it as my dd? (i use 2wd all the time)
-SOLD-
1997 Grand Cherokee 5.2 Limited - D44a Trussed 4.10 Gears - HP30 4.10 Gears - NP242 - IRO HnT - IRO Custom Drive Shaft - 4.5" lift - JKS Quicker Disconnects -
RC Front ADJ. Trackbar - IRO Rear ADJ. Trackbar - Rusty's Lower ADJ. CA's - Front tow hooks - Rear OE Hitch - T-Case Skid -
Gas Tank Skid - Bilstein 5125's - 31" MTR's - Magnaflow SS Muffler - 1.25" Wheel Spacers - Custom Rock Sliders - Cobra 19 DXIV
I am an Authorized IRO dealer!!
SILASPRIT is offline   Reply With Quote
Old 01-15-2009, 04:03 PM   #2
Jason, aka: Jeepin.com
Vendor
Jason, aka: Jeepin.com's Avatar
1995 XJ Cherokee
if such a part existed...
Jason West - Jeepin.com | JeepinOutfitters.com
'95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc.
'09 JK, Unlimited Rubicon, RE 3.5", 35" BFG KM2s, Expedition One bumpers, T&T rockers & skids, XRC10 Comp
'00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
Jason, aka: Jeepin.com is offline   Reply With Quote
Old 01-15-2009, 04:05 PM   #3
SILASPRIT
oh hahaha what about welding my spider gears?
-SOLD-
Old 01-15-2009, 04:34 PM   #4
jackdes
1992 XJ Cherokee
no that won't work
jackdes is offline   Reply With Quote
Old 01-15-2009, 06:05 PM   #5
1990JEEPXJ
1990 XJ Cherokee
Originally Posted by jackdes View Post
no that won't work
why wouldnt welding the spiders work on a disconnect axle?
Twin 242's
The 'build' thread
1990JEEPXJ is offline   Reply With Quote
Old 01-15-2009, 06:18 PM   #6
SILASPRIT
i just dont see why i would have to pay 250 to lock the front when i have a disconnect axle.....
-SOLD-
Old 01-15-2009, 06:24 PM   #7
XJLI
1993 XJ Cherokee
itll work at breaking it.
Factory Four Link
XJLI is offline   Reply With Quote
Old 01-15-2009, 07:11 PM   #8
ep191
x2
spooling/welding a front axle is not in your best interests
ep191 is offline   Reply With Quote
Old 01-15-2009, 07:11 PM   #9
tate228
1995 XJ Cherokee
I don't see why it wouldent work. if you wheel it hard it'll break but i say go for it.
1995 sport 4.0/ax15/np231, 3in lift, moab wheels, 245-75-16 goodyear mtrs
1987 4.0/aw4/np242 dana 44 (RIP)
tate228 is offline   Reply With Quote
Old 01-15-2009, 07:34 PM   #10
XJLI
1993 XJ Cherokee
ive seen one break on the street. but by all means, do what you want.
Factory Four Link
Old 01-15-2009, 08:01 PM   #11
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
I personally wouldn't trust the collar to hold up to wheeling with a welded diff.
I'd convert to one piece axle shafts (on the one side at least) and then add an Aussie for $250. That will live a hell of a lot longer and put less wear and tear on your axle shafts.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 01-15-2009, 08:14 PM   #12
SILASPRIT
i think i will go with an aussie and if i do have probs with the actuator then do a one piece swap.... but i want to try the locker with the disconnect because i can disconnect it at any time and have 2wd even 2lo hahaha
-SOLD-
Old 01-15-2009, 08:34 PM   #13
chainerx
1997 XJ Cherokee
If you Aussie the front but disconnect the axle, wouldn't you be in "3-low"?
chainerx is offline   Reply With Quote
Old 01-15-2009, 08:49 PM   #14
Racin444
Ok paint the tread on your tires and make a right or left turn. Then look at the pavement and see if the marks are the same length. They wont be. The outside tire has to spin more than the inside tire so a mini spool or welded gears would not allow you to turn on pavement. A DD would need a air locker or electric locker to be used on pavement all day. Dont even think about messing with the front axle unless youre putting a locker in it
2008 Black Wrangler X 6 speed
3" Teraflex lift with 37 MTR Kevlars fully armored locked front and rear
Racin444 is offline   Reply With Quote
Old 01-15-2009, 09:31 PM   #15
Vendor
1995 XJ Cherokee
Riiiiight... except for the fact that's he's got the old style vacuum disconnect D30 front end, which is kinda like having a manual hub on one side.
As far as needing an air locker or electric, that's not correct, vacuum disconnect or not. Lunch box lockers, like the Aussie, and the Detroit locker all require power input through the pinion to lock up, so in 2WD they should always be unlocked. If you need to use 4WD on the road, then yes, you're best off with a selectable locker, otherwise in 2WD more any locker should be invisible on the street.
Glock Forum
