milky oil? - JeepForum.com
post #1 of 13 Old 06-21-2013, 08:18 PM Thread Starter
josh1011
milky oil?
so i got my jeep from a guy who never changed the oil in it "that im aware of" but as of now it has 214,700 miles on it. I changed the oil last summer and the filter and untill now i only put 30 miles on it, i only went mudding with it in about 2 feet of water and today i changed it again and its very milky and smells like gas. i have no idea what it is and also while its at idle it makes a rattle noise and shakes pretty bad i even pulled of # 4 plug wire and the motor rpm never changed.
josh1011 is offline
post #2 of 13 Old 06-21-2013, 10:39 PM
Floreancig_XJ
What year, if 2000 /2001 google 0331 jeep head, enjoy ypur night!!
Floreancig_XJ is offline
post #3 of 13 Old 06-21-2013, 11:21 PM
BigBadWuf
1992 XJ Cherokee
Sounds like you have a couple problems.
1. Was the oil milky before you went thru the water?
If so, sounds like either a bad head gasket, warped/ cracked head, or cracked block. If it wasnt milky before it could be that you sucked water into the motor which will take at least a couple oil changes to get it all out, or drop the pan and clean it.
2. If your oil smells like gas, its running to rich which will kill the rings and bearings.
3. What year is your jeep, tell us so we can give advice for rich mixture. It says 91? So its a 91 cherokee?
4. Sounds like a dead miss on cylinder 4, does cylinder 4 have spark?
5. Do a compression test, if the miss started after you sucked water in the motor it could be cyl. 4 has no compression because you bent a valve.
6. Report back with findings
BigBadWuf is offline
post #4 of 13 Old 06-22-2013, 05:53 PM Thread Starter
josh1011
It is a 91 anf yes it does smell like gas and im pretty sure it had the miss. But also I ran it out of gas all the way one time could it just be a bad injector
josh1011 is offline
post #5 of 13 Old 06-22-2013, 08:05 PM
jtcnj
So what do you expect from xj this overall?
"Lay Down Sally" Silverstone Metallic 2001 xj sport 4.0L/AW4/231/8.25 mostly stock.
"Dubyuh" or "Blue Bayou": Patriot Blue 2001 Up-Country WJ Limited 4.7L V8 Quadra Drive: for now known as "Al-Dente" after my wife's "mod".
New Addition 12/2011: "Pearl" Forest Green Pearlcoat 1999 xj SE 4.0L/AW4/231/8.25 mostly stock for now.
____________________________________________
I didn't agree, but hoped for Hope and Change.
I got change for myself and my family: for the worse.
This is the reality of: Barackalypse Now. Again.
"The most terrifying words in the English language are: I'm from the government and I'm here to help."
Ronald Wilson Reagan
jtcnj is offline
post #6 of 13 Old 06-23-2013, 09:50 AM Thread Starter
josh1011
I just dont want to be driving somewhere and the motor take a **** because it was a simple thing I could fix
josh1011 is offline
post #7 of 13 Old 06-23-2013, 01:27 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
You got your $200 worth of fun out of that Jeep.I hope you didn't pay more than that.
TheBoogieman is offline
post #8 of 13 Old 06-23-2013, 01:30 PM
TheBoogieman
Disturbed
Don't believe the hype.Jeep produced hundreds of thousands of 4.0's that didn't have head problems.XJs,ZJs,TJs.
p.s. It's 99-2001.
post #9 of 13 Old 06-23-2013, 01:31 PM
TheBoogieman
Disturbed
500,000 miles and no rust or repairs.
post #10 of 13 Old 06-23-2013, 04:53 PM Thread Starter
josh1011
Would it be worth buying a used motor I got the jeep for free
josh1011 is offline
post #11 of 13 Old 06-23-2013, 05:14 PM
Floreancig_XJ
Ofcourse they did, i didnt say 100% thats it.. No
post #12 of 13 Old 06-23-2013, 05:15 PM
Floreancig_XJ
If its a free jeep and the bodys good, and floors... Try and look around even a rebuilt
post #13 of 13 Old 06-24-2013, 09:07 AM
Pats94
Why not. Do a jy motor put it in yourself. Cheap wheels.
If its stock it sucks and if it scares the hell outta ya its just about right!
Pats94 is offline
