Measures 6 inches, doesn't look like 6 inches...
#31 | ||
93 Cherokee Sport 4.0 5 speed(ax15), np231 8" Lift 36" TSL's on RockCrawler rims www.PGHOFFROAD.com |
#32 | ||
Here's mine. Pretty much the same setup as yours... Rusty's 3" with 1.75 spacer and RE boomerang shackles for 5.5" (actual measured) front and rear on 31's. ![]()
ΜOΛΩΝ ΛΑΒΕ .--- . . .--. ..-. --- .-. ..- -- / -- .. .-.. .. - .. .- / -- . -- -... . .-. BLUE JEEP CLUB MEMBER #152 BUSHMAN'S JEEP CLUB Quote:
#33 | |
Here is one more crappy pic but from a different angle...
#34 |
Awesome, thanks for the pics. I guess tire really do make the difference. Mine looks just about like yours. Does yours have a raked look to it at all? (like roofline)
1990 XJ Laredo 4x4 Auto *Rusty's ~6" Lift *Dana30/Dana44 3.55's *Pacer Wheels/High-Tec Retreads 31" MT *KargoMaster Safari Rack *CSF Open Cooling System Conversion *Hayden Tranny Cooler *Flowmaster 40 Delta & High-Flo Cat *PORC SYE / FRT DS Combo *The Doors are off again for summer! |
#35 |
Deff, trim those fenders and stuff some 33s in there.
mine is the marron one sitting on 6.5" of lift, full coil and leaf.. mine actually sits lower in the rear due to leaf sag. I am running 35" tires. 35s are as big as i can go. any bigger would rub bad at full stuff. The blue one (my buddys) is sitting on over 5" of lift with 34s. both of our fenders are trimmed to the max. ![]() ![]() ![]()
THEDERRICK106 DD: 1998 ZJ 4.0 6" RK long arm. 33" BFG ATs ected and alloy usa shafts up front super 35 in the rear... 456 gears... Wheeler: 1998 TJ 4.0 5spd 2.5" OME lift. 33" trxus MTs lock-right up front with superior axle shafts. smittybilt winch...etc... www.adirondackjeeps.com |
#36 |
Here is my xj next to my tj with 31s just for a reference. (doesnt look so tall next to another lifted xj)
#37 |
dakuda is a god
Front = 12inches
Back = 12 1/4 inches By your mearusement thing. So, how much accual lift do i have? |
#38 |
measure from center of rim to bottom of flare.
stock is 17 front 17.5 rear. (i think)
Build Thread- Includes bastard pack and cheap 3" lift info Red 97 XJ Sport 5 Speed - Lifted 3" - Sound system - C4X4 Tow Hooks - Hella 500s Black 96 XJ Classic - Stocker on 31s - SOLD |
#39 |
dakuda is a god
I used the method he did, there is a link in the origional post
#40 |
dakuda is a god
ok, i firgured it out
Front = 5.25 inches of accual lift Rear = 6 inches of accual lift The front of mine is all messed up not tho, the coil spacer is all crushes and is letting the front sag a bit |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
