Quantcast Measures 6 inches, doesn't look like 6 inches... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Measures 6 inches, doesn't look like 6 inches...
Old 01-28-2007, 04:31 AM   #1
RickyN29
Well, taking a look at my suspension due to the possibility of going a little higher, I decided to measure everything to determine exactly what sort of lift I am sitting at.
Using the fender to hub method (stock 17.5" center hub to flare, 17" rear), and using the OEM measurements found here:
http://www.mike-g.net/jeep/yinyang/tech/rideheight/
I measure mine out exactly to:
23" hub to flare (so 6" over stock of 17")
12" front and rear (axle tube to body according to website) (stock is 6", so again confirmed 6" lift)
This means that I am sitting on a 6" lift front and rear..... right?
Now, my Jeep has a racked look to it, and measuring the roofline, it is definitely taller in the rear. Suspension measurements show my Jeep to be sitting 'technically' level though. Any input?
Also, why does a "6 inch lift" look SUBSTANTIALLY taller than mine???
Here is my suspension:
Front:
3.5" coils, 2" spacer, .5"isolator
Rear"
3.5" packs, 2" shackle, AAL (not sure on measurement)
31" tires.
Pics:
What gives?!?! Are you guys actually getting a lot more lift out of your kits than advertised or something? I'm confused.
1990 XJ Laredo 4x4 Auto
*Rusty's ~6" Lift
*Dana30/Dana44 3.55's
*Pacer Wheels/High-Tec Retreads 31" MT
*KargoMaster Safari Rack
*CSF Open Cooling System Conversion
*Hayden Tranny Cooler
*Flowmaster 40 Delta & High-Flo Cat
*PORC SYE / FRT DS Combo
*The Doors are off again for summer!
RickyN29 is offline   Reply With Quote
Old 01-28-2007, 04:48 AM   #2
craminator66
Yeah, my 4.5" lift actually gave me 5.5".
00' XJ (lift, tires, HP dana 30 4.10's, Aussie Locker in front)
craminator66 is offline   Reply With Quote
Old 01-28-2007, 04:52 AM   #3
RickyN29
And I bet yours looks higher than mine. I mean, mine looks like a 3" lift. Grrr
*Rusty's ~6" Lift
Old 01-28-2007, 04:57 AM   #4
xj BMX xj
1992 XJ Cherokee
cant help you with your dysfunctional lift but those pictures are amazing (right click save-as)
92 Cherokee Trail toy. - 97 Cherokee Street toy.
XJcruiser: Crumple zones? I guess the other car will have to share those.
xj BMX xj is online now   Reply With Quote
Old 01-28-2007, 05:40 AM   #5
Srhmn8r
Toilet Recycling?
03 Rubicon RE 3.5" and 1.25" JKS BL 285/75/16 Kumho MT's
Srhmn8r is offline   Reply With Quote
Old 01-28-2007, 06:25 AM   #6
Arcticcat843
dakuda is a god
Arcticcat843's Avatar
1980 CJ5
Id say its a 4.5 inch lift and 31's
If you look at the distance between the top of the tires to the bottom of the flare it looks the same as mine.
Arcticcat843 is offline   Reply With Quote
Old 01-28-2007, 07:09 AM   #7
basso4735
1997 XJ Cherokee
the rear starts out @ .5" taller than the front, anyway.
edit, sure those tires are 31s? lol. looks a lot like artic's lift.
Build Thread- Includes bastard pack and cheap 3" lift info
Red 97 XJ Sport 5 Speed - Lifted 3" - Sound system - C4X4 Tow Hooks - Hella 500s
Black 96 XJ Classic - Stocker on 31s - SOLD
basso4735 is offline   Reply With Quote
Old 01-28-2007, 07:27 AM   #8
Arcticcat843
dakuda is a god
1980 CJ5
Mine are 31's
Old 01-28-2007, 07:32 AM   #9
basso4735
1997 XJ Cherokee
yeah, thats kinda weird.
Old 01-28-2007, 07:38 AM   #10
Arcticcat843
dakuda is a god
1980 CJ5
whats Weird
Old 01-28-2007, 07:59 AM   #11
basso4735
1997 XJ Cherokee
how his lift looks like yours exactly, and hes supposed to have 3" more.
Old 01-28-2007, 08:55 AM   #12
Goldenknob
1992 XJ Cherokee
Originally Posted by Srhmn8r
Toilet Recycling?
lol I saw that too wtf is that?
Goldenknob is offline   Reply With Quote
Old 01-28-2007, 03:26 PM   #13
Wisbar
What is Rusty's 5.5" HD lift? Looking at your specs and Arcticcats specs I am guessing your XJ's are about the same. Arcticcat's running Rusty's 3" with spacers and shackles which would probably give him close to 5.5" (guessing cause that's what I have and 5.5" is what I have). Your Jeep looks very close to mine height wise and I'm at 5.5" as well with 31's.
Your not measuring wrong... It's the tires. Most people have at least 33's and some 35's on that much lift and thats probably why their Jeep looks alot bigger even with the same amount of lift. I get a weird complex when I look at a XJ with less lift but larger tires, and it looks way bigger than mine . I think 31 or 32's fit better and no trimming but just don't do the lift any justice.
Awesome Jeep and sweat pics by the way!
ΜOΛΩΝ ΛΑΒΕ
BLUE JEEP CLUB MEMBER #152
BUSHMAN'S JEEP CLUB
Originally Posted by Ski01xj
"your becoming more of a redneck every time the UPS man shows up"
Wisbar is offline   Reply With Quote
Old 01-28-2007, 04:03 PM   #14
Lagooz00XJ
other 6" lifts look bigger because they are on rigs with trimmed fenders and larger tires. Trim those fenders and run a 33/35" tire and it will look huge.
2000 XJ 4.0 aw4 np 242
Bastard 2.5" Lift
30" Kumho MT's
Belly Armor
RE H&T w/ front shaft
Lagooz00XJ is offline   Reply With Quote
Old 01-28-2007, 04:43 PM   #15
andrew2516
Here's mine at actual: 6" on 34"s in front of a xj with 2" BB
93 Cherokee Sport 4.0
5 speed(ax15), np231
8" Lift
36" TSL's on RockCrawler rims
www.PGHOFFROAD.com
andrew2516 is offline   Reply With Quote
Glock Forum
