mass air flow sensor - JeepForum.com
post #1 of 15 Old 08-18-2007, 07:16 AM Thread Starter
dustin5188
dustin5188's Avatar
can someone tell me where the mass air flow sensor is on a 96 cherokee with an inline 6. Is it hard to replace?
RED JEEP CLUB:MEMBER#395
dustin5188 is offline
post #2 of 15 Old 08-18-2007, 07:53 AM
severous01
severous01's Avatar
there's not one. it's a speed/density setup with a Air Intake Temp and a M AP sensor
severous01 is offline
post #3 of 15 Old 08-18-2007, 09:09 AM
tangofox007
Just curious, how did you conclude that a nonexistent component needs to be replaced?
tangofox007 is offline
post #4 of 15 Old 08-18-2007, 10:16 AM Thread Starter
dustin5188
dustin5188's Avatar
guy at autozone told me since i hap replaced map and intake air temp sensors then it had to be the mass air flow sensor, check engine light keeps coming on for bad map sensor but i have replaced it, what could be the problem.
post #5 of 15 Old 08-18-2007, 11:34 AM
tangofox007
guy at autozone told me....
That explains everything!!!
How is the MAP sensor vacuum line and connections?
post #6 of 15 Old 08-18-2007, 12:00 PM Thread Starter
dustin5188
dustin5188's Avatar
the vacum line and connection all seems good, ive been reading a lot of post about the same problems. When iam ccelerating from a light it acts as if the gas cuts out even tho my foot stays in the same position then all of a sudden the gas kicks back in and i go flying forward. Check engine light keeps saying bad map sensor but i have replaced it. Also have replaced the following:
plugs and wires
rotor button and distrubutor cap
tps
iat sensor
map sensor
fuel filter, and had addiatives ran in fuel system
it ran fine for several months after my mechanoic had it, he said he changed the plug wires, should i check each wire and plug for bad arching, if they are arching bad how do i fix it?
post #7 of 15 Old 08-18-2007, 01:42 PM
severous01
severous01's Avatar
there are a few things other than a dead MAP that will cause a SES code.
1. vacuum leak.
2. bad return or power to the MAP...check for stretched or broken wires, connectors and at the PCM
3. a faulty, but not broken completely, TPS will trick the pcm into throwing a map fault.
for the wires, ohm them out. that's it.
post #8 of 15 Old 08-18-2007, 06:12 PM
242much
2009 JK Wrangler
x2 on the tps. also, have you checked your grounds? i know it sounds stupid, but if the motor's not grounded properly, it can do some really screwy stuff.
"The stoke was palpable..."
good grief, just buy the Rubicon.
242much is offline
post #9 of 15 Old 08-23-2007, 09:36 AM Thread Starter
dustin5188
dustin5188's Avatar
the tps is also new, what about a o2 sensor
post #10 of 15 Old 08-23-2007, 09:47 AM
BlkBird
Did the guy at AZ scan and read the codes? Did he tell you what the code was? I hate to say this but if he did'nt, go back up there and have them scan it and tell you the code. DO NOT buy anything from them on the spot. Come back, let us know what it is and we can point you in the right direction. Diagnosing without checking the codes is just guessing and all you are doing is wasting money throwing parts at it.
2004 Wrangler X 4.0
2000 Cherokee Sport 4.0
1992 Dakota Sport 5.9
1971 Pontiac Firebird
BlkBird is offline
post #11 of 15 Old 08-24-2007, 09:02 AM Thread Starter
dustin5188
dustin5188's Avatar
the scanner says it was the map sensor, code # 107 but i have already replaced it, ive been told the O2 sensor is the problem
post #12 of 15 Old 08-24-2007, 08:44 PM
Rock Kustoms
Rock Kustoms's Avatar
why not just replace the motor. throwing parts at a problem usually just ends up wasting money. i have seen shorting out o2 sensors cause issues like that. your jeep has 2 o2 sensors, upstream and downstream, no matter what anyone trys to sell you, a downstream (after cat) o2 sensor does NOTHING for fuel management, its soley there to set a check engine light if the cat isnt working to spec.
the simplest way to verify if the upstream o2 sensor is your problem is simply to unplug it. the jeep will always be in open loop when you do this, so it will run rich, waste gas etc, so its not a permant fix, but drive it for a few days, if the problem goes away, change the o2 sensor
Rock Kustoms is offline
post #13 of 15 Old 07-21-2011, 06:53 PM
JOMOjeep31
My 99 wrangler is doing the same stuff
I just copied this from a different forum
My 99 Wrangler's check engine light and airbag light came on about 2 weeks ago, when i accelerate the jeep jumps and is jerky, .. I have had auto zone and a local shop run the computer tests, and it first came up at autozone as the TPS sensor so i changed that, and it still did it, so i took it to a shop and their test said TPS sensor still and clock spring.. I switched out for another TPS sensor and put in throttle body cleaner, fuel injector cleaner, new spark plugs and new wires, and it has gotten worse. It will sometimes die in neutral and it feels like it wants to when i slow down, and it really jerky now.
I've had heard that it could be a fuel filter, fuel pump, mass air flow sensor. Basically i've heard a million things... Im just trying to see if anyone has any idea, i really appreciate any feedback
JOMOjeep31 is offline
post #14 of 15 Old 07-22-2011, 06:53 AM
whitexj98
Codes don't tell you to replace part x, they are a start to a diagnosis. And i wouldnt trust diag to autozone
whitexj98 is offline
post #15 of 15 Old 07-22-2011, 06:02 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
How come you're ignoring Post #7?
cruiser54 is offline
Check Engine Light Scan Question - Evap Purge Flow Sensor bmyohn XJ Cherokee Technical Forum 22 11-24-2013 07:38 AM
O2 sensor on Magna Flow cat? 96-XJ XJ Cherokee Technical Forum 10 10-25-2009 08:08 AM
TPS sensor, Coolant temp sensor, and 02 Sensor fail kadetklapp XJ Cherokee Technical Forum 2 09-07-2008 01:48 PM
Mass Airflow Sensor Cherokee2000 XJ Cherokee Technical Forum 5 03-13-2008 04:47 PM
Question about Mass Airflow Sensor beefcake XJ Cherokee Technical Forum 6 06-03-2004 09:34 PM
