map sensor problems HELP!!! - JeepForum.com
post #1 of 4 Old 02-11-2011, 05:04 PM Thread Starter
ty1123
1988 XJ Cherokee
ok so i have an 88 xj 4.0 efi, ive been having problems with it running extremely rich for a few months ive gone through everything i could possibly think of and then i replaced the map sensor and it idles WAY better and its not running so rich at an idle but then when i give it a little gas it misses and backfires and a **** ton of black smoke comes out the back. and it only is like that when the map sensor is hooked up...i take the vacuum line out of the throttle body and its back to running rich but it doesnt miss and backfire anymore. im at my wits end on this and its getting very irritating and expensive. any input is greatly appreciated.
Buckle up...I wanna try something ;)
ty1123 is offline
post #2 of 4 Old 02-12-2011, 06:14 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Have you verified proper fuel delivery? If not, should do so.
For an 88, you should have 31 psi at idle. Then disconnect the vacuum line leading to the fuel pressure regulator and the pressure should jump to approx. 39 psi. Also be sure that the FPR vacuum line is pulling good vacuum and is not wet with fuel. If that vacuum line has gas in it, replace the regulator.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #3 of 4 Old 02-12-2011, 09:30 PM Thread Starter
ty1123
1988 XJ Cherokee
OK thank you, i will do that tomorrow and let you know what happens.
appreciate the input.
ty1123 is offline
post #4 of 4 Old 02-13-2011, 03:32 PM Thread Starter
ty1123
1988 XJ Cherokee
ok so i put a new FPR on it and a fuel filter as well and it still misses and backfires when i hook up the map sensor. i dont know what else to do
ty1123 is offline
MAP sensor problems longtravel1 XJ Cherokee Technical Forum 2 01-03-2009 07:58 PM
Sensor Problems please help!!! Wagoneer Man XJ Cherokee Technical Forum 1 07-30-2006 09:51 PM
O2 Sensor problems Rescue XJ XJ Cherokee Technical Forum 6 05-23-2006 03:32 PM
O2 sensor problems, Speed Sensor 400lbguerrilla XJ Cherokee Technical Forum 6 11-05-2003 05:50 PM
O2 sensor problems 400lbguerrilla XJ Cherokee Technical Forum 1 11-03-2003 10:54 AM
