map sensor 92 xj - JeepForum.com
post #1 of 11 Old 04-23-2010, 10:32 PM Thread Starter
JOEGUYZXJ
1992 XJ Cherokee
map sensor 92 xj
ok having problems with the heep , anyone ever have the map sensor go bad ? what years will fit my 92 xj 4.0 ??? what does it do ? hows it work ?
sorry for all the questions , just going broke fast
coalregion4x4.webs.com
JOEGUYZXJ is offline
post #2 of 11 Old 04-24-2010, 06:02 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Yes, they do go bad. They also can appear bad becuse the wires aren't plugged in well or the connection is dirty. More commonly, the vacuum line going to them is leaking vacuum, sendig the MAP a false signal. I believe they were the same from 87 to at least 95. Your local parts guy will know. The MAP sensor reads your manifold vacuum and sends a signal to the ECU so it can adjust fuel delivery according to engine load. If it's bad, your Jeep will run very rich, blowing black smoke.
cruiser54 is offline
post #3 of 11 Old 04-24-2010, 06:35 AM Thread Starter
JOEGUYZXJ
1992 XJ Cherokee
how about a popping in the intake ? new fuel pump ,filter ,dist, plugs, wires, cap rotor, cleaned the throttle bodie, seems to happen while the jeep is just about normal temp i have replaced all of the above i am getting some carbon on my hand if someone revs it up and i stick my hand behind the exust , not much though , like i said its while it is warming up or about 4 miles from home , work while driving , cel doesnt go on though
post #4 of 11 Old 04-24-2010, 06:43 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Are you saying it does this only while warming up and it's okay after that? I would look for vacuum leaks in all those vacuum harnesses under the hood. The rubber connectors can deteriorate and the hard plastic lines can crack or develop pinholes. Your CCV system, the lines to the valve cover, should be removed and cleaned to be sure they aren't clogged. About $8 to replace the rear tube with grommet and orifice. Did you check out yur MAP vac harness and connector yet? I'd quit throwing expensive parts at this and look for maintenance items like these that need to be addressed. You ought to refresh all you grounds at the dipstick tube and head to firewall while you're at it. Refresh means removing, scraping, polishing and reinstalling. Clean and shiny.Check all your intake manifold bolts/nuts and see if they have loosened up, too.
post #5 of 11 Old 04-24-2010, 02:59 PM Thread Starter
JOEGUYZXJ
1992 XJ Cherokee
yes seems to happen when its getting warmed up more than when its at normal temp going to check the grounds out now , map sensor seems like no leaks comming from it (used soapy water)
post #6 of 11 Old 04-24-2010, 04:44 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Map sensor and coolant sensor can be tested with a manual and a meter. Both are involved with determining fuel/air ratio.
Have you verified fuel pressure at the fuel rail? Would be one of the first things I would do if it were mine. Gotta use a gauge. Backfiring in the intake can be indicative of a "lean" condition. You replaced the fuel pump but there is still a regulator at play here.....Compare your readings to factory spec.
Test your way to a solution.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #7 of 11 Old 04-25-2010, 09:04 AM Thread Starter
JOEGUYZXJ
1992 XJ Cherokee
yes have tested fuel pressure ,its good , asked jeep dealer mech, temp sensor is gettting changed today seee how it goes from there post up my findings asap
post #8 of 11 Old 04-29-2010, 10:21 PM Thread Starter
JOEGUYZXJ
1992 XJ Cherokee
changed temp sensor ok well i changed the one in the termostat housing is that the correct one ? only happens if its colder out and i get in and drive , if i shut it down and restart no problems for the rest of the day ,, again i did change the sensor in the termost housing not the back one with one should i have changed ? any other suggestions
post #9 of 11 Old 04-30-2010, 10:29 AM
BassMasterCHS
1993 XJ Cherokee
The front one is for the ECU. The one on the back of the block is for the dash gauge. So you swapped out the correct one!
3 Inch lift, 30" BFG AT's, Walmart lights up front.
BassMasterCHS is offline
post #10 of 11 Old 04-30-2010, 11:26 PM Thread Starter
JOEGUYZXJ
1992 XJ Cherokee
is there somewhere i can go to have the jeep put on a computer that wont cost me a arm and a leg to see if that will find the problem ? autozone maybe ??? idk just a thought
post #11 of 11 Old 05-01-2010, 06:15 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Yeah, Autozone.
Check Engine Light - 02 sensor voltage too high bank 1 sensor 2 billbarr100 XJ Cherokee Technical Forum 15 05-19-2010 03:04 PM
Pulling VSS, Cam Position Sensor, and Bank 1 Sensor 2 Codess 9Classic8 XJ Cherokee Technical Forum 7 03-09-2009 02:43 PM
TPS sensor, Coolant temp sensor, and 02 Sensor fail kadetklapp XJ Cherokee Technical Forum 2 09-07-2008 01:48 PM
halls effect sensor or camshaft position sensor? mackg@goodweb.o XJ Cherokee Technical Forum 4 07-13-2007 06:23 AM
P0138 Oxygen sensor high voltage, bank 1 sensor 2 Back2Basics XJ Cherokee Technical Forum 3 08-03-2004 11:33 AM
