Manual Window Regulator - JeepForum.com
post #1 of 11 Old 05-18-2010, 09:53 AM Thread Starter
mctwin2kman
Can anyone point me in the right direction to replace or repair my manual window regulator, drivers side? I can not for the life of me either find the part online to replace it or even any information for repair. Every search I do comes up with damn power windows. What do I have the only XJ with manual windows or something? Anyway, it works and all, but I can not roll the window all the way down or else it will not come back up. All other windows work perfect except for the drivers. Just get the nice clickity click due to worn teeth. I have seen at auto parts stores where you can get the GM style plastic toothed strip and cut to fit but I am not sure if that would be able to be fitted into the Jeep track. Does anyone know if there is something out there I can get to fix this, or know where to get a regulator assembly to replace mine? Granted I only paid $250 for this beast so I do not want to spend a boatload to fix a window.
Thanks.
mctwin2kman is offline
post #2 of 11 Old 05-18-2010, 10:29 AM
93gc40
Junkyards and Ebay, both have lots of manual window regulators. I have gotten them both ways.
96 XJ 4.0 / 231 / 3.5" JY Lift/ 31" BFG /.....
93 VT1100 - Harley killer.
97 ZJ 4.0 / 242 / Stock
93 ZJ 4.0 / 2"BB / Wranglers / RIP-Gone but not forgotten.
If it aint dirty, it aint a JEEP, it's just a SUV.
93gc40 is offline
post #3 of 11 Old 05-18-2010, 11:25 AM
mfalik
mfalik's Avatar
Try www.car-parts.com , this will show all the salvage yards that have the part.
Look under "front door regulator".
Below the instructions for removing the window regulator (it includes the instructions for both power and manual windows, so just ignore the power section).
MichiganTech Mechanical Engineer Alumni
1994 Wrangler Sahara - Jeep Project
2003 Dodge Ram 1500 (new truck)
2007 Mazda CX-7 (the new commuter car)
2005 Mitsubishi Lancer (Rear Ended - TOTALED)
1998 VW Beetle (SOLD)
1988 Jeep Cherokee Limited - (SOLD)
Last edited by mfalik; 05-18-2010 at 11:41 AM. Reason: Added regulator instructions.
mfalik is offline
post #4 of 11 Old 05-19-2010, 10:13 AM Thread Starter
mctwin2kman
Thanks guys. I figured I would have to go that route. Just find it strange that you can find all the info you want on power ones but virtually nothing on manual ones.
post #5 of 11 Old 05-19-2010, 10:56 AM
GeologistFelix
1990 XJ Cherokee
Probably because the power ones break more often.
GeologistFelix is offline
post #6 of 11 Old 05-19-2010, 11:55 AM
minitruck83
1994 XJ Cherokee
Are you sure its worn teeth?
My window only go's halfway down and then stops, if you try to take it further, it won't move but will no longer come back up without pulling it up about an inch before it catches again.
The lower third of the 'fuzzy worm' regulator strip was rusted off.
I got a replacement at the pick yard for $2 but drilling out the rivets in the field didn't work so well! (ran 2 battery's down) Ended up punching them out, which in my case was easier and faster than drilling. I just broke the window out rather than trying to get to the door glass stud, getting it out looks to be the hardest part of the job.
Have been staring at it for a few months now trying to figure out if I can somehow change out only the regulator strip, and avoid that door glass stud. Don't need to break my good window. So I cant tell how to reinstall yet.
BTW it came out the front access hole (speaker) easier.
Allen
minitruck83 is offline
post #7 of 11 Old 05-19-2010, 02:19 PM
tangofox007
Originally Posted by mctwin2kman View Post
....but I can not roll the window all the way down or else it will not come back up.
I had the same problem. I glued a wood block to the bottom of the door to prevent the window from going all the way down.
tangofox007 is offline
post #8 of 11 Old 05-19-2010, 02:51 PM Thread Starter
mctwin2kman
I need to look at it again but I am assuming that the end of the strip has worn teeth since the handle just spins, I have to actually push the window up enough and turn the handle for it to re-engage. It happens when there is roughly less than an inch of glass above the weather strip.
post #9 of 11 Old 05-19-2010, 03:16 PM
lowicz96
1995 XJ Cherokee
Have you taken your door apart to verify? My drivers power window did this and it was due to a broken cable or band or something like that
Project/DD - 95' Cherokee Sport, 2 Door, Converted to 4x4, AX-15, NP231, Black and lots of other goodies
88' Cherokee Limited - RIP
Sold - 96' Cherokee Sport 4x4, 2 Door, AW4, NP242, Its the girlfriends now!!
lowicz96 is offline
post #10 of 11 Old 03-14-2013, 11:01 PM
tonka89
1989 FSJ Cherokee
hey ya'll my glass channel screw is a nut and it turns but don't come lose any help would be great its a 89 Cherokee thanks ya'll
tonka89 is offline
post #11 of 11 Old 04-19-2016, 05:54 PM
Jones_m_s
1989 XJ Cherokee
Will any Mopar in that year range work? Or does it have to be a cherokee? I got mine out to find the same problem with the fuzzy strip and the metal winding seems to be thinner there too.
Jones_m_s is offline
Need a window regulator for 89 MJ jwassom MJ Comanche Technical Forum 3 07-12-2007 03:07 PM
Window regulator fix. jimmydaux XJ Cherokee Technical Forum 7 05-18-2007 05:19 PM
window regulator bjornski7 XJ Cherokee Technical Forum 5 10-17-2006 08:33 PM
manual window regulator 88 XJ tigerpaw580 XJ Cherokee Technical Forum 5 08-07-2005 01:42 AM
How to remove window regulator (manual window) kairo XJ Cherokee Technical Forum 6 06-20-2005 09:04 PM
