Quantcast Manual to Automatic Swap - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Manual to Automatic Swap
Old 10-24-2005, 03:41 PM   #1
bigjohn73
I have a 93 Cherokee Sport 2WD with a 4.0L and 5 speed. The clutch is worn out and I pulled the transmission. While looking at rebuilt clutch kits in the 160-180 dollar range, I started considering swapping over to an automatic. I really enjoy driving cars/trucks with a manual trans, but my left knee is shot, and I am looking several more surgerys on it. Since all of my cars are standard, this cuts into my driving a bit. Is there a non-computer controlled overdrive transmission that is worth swapping into my Jeep. I realize I will have to add an automatic shifter, transmission cooler, modify/ buy different driveshaft, ect. Right now would be the time to look at swapping it while my transmission is sitting on the shop floor and I would be looking at spending money on the manual trans anyways.
bigjohn73 is offline   Reply With Quote
Old 10-24-2005, 03:51 PM   #2
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Why not use an AW4? That way, you can pull all of the necessary parts off of a junked rig.
"'Did you ever wonder why we had to run for shelter when the promise of a brave new world unfurled beneath a clear blue sky? "
Roger Waters
Matt Gertsch is offline   Reply With Quote
Old 10-24-2005, 04:07 PM   #3
bigjohn73
If I use the AW4 I will need to swap the computer and wiring for computer controlled transmision, right? Are there years of the AW4 that are non-computer controlled?
Old 10-25-2005, 12:30 PM   #4
Matt Gertsch
www.lp.org
You'd need the trans computer, but there isn't that much wiring that you'd need to do. All of the needed sensors are already in place. As far as I know, all AW4s are computer controlled. You could get a non lockup 700R4 or a TH350. There are kits on the market to adapt the 4.0l to the tranny.
Roger Waters
Old 10-25-2005, 12:35 PM   #5
fryed_1
I have a 93 AW4 if you want to come to VA to come and get it.
'94 XJ - 8" Long arms, 9" rear, 35's
'89 Waggy
'48 Willys
fryed_1 is offline   Reply With Quote
Old 10-25-2005, 01:01 PM   #6
cmotsvt
Just a thought but can you bypass the computer totally using one of those shifter switch deals that are out there? Then would have a manual automatic.
cmotsvt is offline   Reply With Quote
Old 10-25-2005, 01:03 PM   #7
Matt Gertsch
www.lp.org
I believe that switch just turns the computer on and off. It makes a lot of heat to constantly have your torque convertor locked like that. I don't know if the AW4 would survive operating like that all of the time.
Roger Waters
Glock Forum
