Quantcast Lubricating slip joint, driveshaft question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Lubricating slip joint, driveshaft question
Old 06-22-2007, 06:09 PM   #1
itasor
2009 JK Wrangler
Lubricating slip joint, which grease?
What type of grease/lubricant should I use to grease my slip joint? I'm following this: http://jeepforum.com/forum/showthread.php?t=357569&page=3
They suggested anti-sieze, someone else suggest wheel bearing grease. Not sure what I should go with.
itasor is offline   Reply With Quote
Old 06-22-2007, 09:05 PM   #2
Matt1994XJ
id go with some kind of grease. anti seize is for bolts
2005 WK 5.7L QDII 245/75-17 on stock
1994 Cherokee 2-Door 4.0L HO w/ 5 speed
SOLD :( Miss it everyday
Matt1994XJ is offline   Reply With Quote
Old 06-23-2007, 08:12 AM   #3
nujeepguy
1997 XJ Cherokee
i'm with matt on this one. i have seen antieize thicken and "gunk" up sliding parts so often. when first used, it actually is a good lubricant but dries up. i would suggest a synthetic wheel bearing/chassis grease. i personally use lucas heavy duty grease. i think that stuff will last over 100 years .
nujeepguy is offline   Reply With Quote
Old 06-23-2007, 09:09 AM   #4
itasor
2009 JK Wrangler
Yeah, anti-sieze didn't sound like the right thing for the job, but they mentioned in the thread that lots of people use it and it seems to last.
I'll probably go with Lucas Heavy Duty Grease, that looks good. Have you personally used it in the spot I'm planning to?
Glock Forum
