#31 | |
bmyohn those gears tht are next to your ring gear i believe is the limited slip well im pretty damn sure it is
Wojtek "who needs paved roads when u have a jeep" 87 xj 6" long arm lift, 35's, 4.88 yukon gears, front detroit true trac colorado jeep club member # 74 |
#32 |
what is it in btw?
94 Ranger XLT - EFI 331, AOD, Dana 20, 4.10s, Trac-lok 8.8, 4" Suspension Lift, 3" Body Lift, 33x12.50s 90 XJ - 230k miles 4" Homemade Lift, 31" TSL's, Lots of Dents - sold 95 Mustang GT - Loves the nitrous When in doubt - throttle it out. |
#33 | |
Youngin'
btw, those pics are from a 8.8" out of a 97 explorer.
2001 Dodge Ram 2500 SLT 4x4 5.9L Cummins Turbo Diesel "The Tow Rig" 1988 Jeep Comanche 2.5L 4cyl - 4 speed manual 2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker 6.5" TnT Customs Longarm Kitl Ford 8.8" w/ disc brakes l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l 35" Maxxis Bighorns l 15 x 8 Cragar Black Soft 8s (4" BS) l High Clearance Shock Mounts l 4 - BAJA off road lights l TnT Customs D30 Truss l Hidden Hitch l ARB Front Diff Cover l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l HP D30 l JKS Mini Skids and Sway Bar Brackets l TnT Customs OTK Steering |
#34 |
i thought it looked a lot like an 8.8
#35 | |
The XJ
1996 XJ Sport, 4.0L HO I6, AX15 5 Speed, NP231, Dana 30/35, Flareless The Daily Driver 2004 Ram 1500, 5.7L Hemi V8, 545RFE 5 Speed Auto, NP241, Chrysler 8.0/Chrysler 9.25, 10mpg |
#36 | |
Personally, I usually check either by doing slow, tight turns on dry pavement - or usually just flooring it and checking how many skid marks I find behind the car ..and if I don't find any, I won't buy it due to lack of bhp/torque ![]()
1998 Grand Cherokee 5.9 LX, 100k miles, 1.75" BB, 32 x 11.50 BFG MT KM2s, custom- fabbed bumpers etc.. http://www.jeepforum.com/forum/f13/daily-driver-5-9-build-thread-bumpers-tube-rockers-etc-1222317/ 1990 XJ Limited (4-door), 4.0 I6, AW4, NP242, ***rolled and totalled @ 165k miles*** ***Under construction*** 1990 XJ (4-door), 4.0 I6, AW4, NP242, PBR 42" tires, Unimog portal axles, 110" WB, full cage + uniframe completely rebuilt, front 3-link + panhard / double triangulated 4-link rear, etc... http://www.jeepforum.com/forum/f11/hybrid-cage-build-exo-cage-internal-973910/ |
#37 |
I have owned a bunch of lsd mustangs, and if your wheel is turning the opposite way , then your clutches are gone, and it may work in a straight line, but not if you floor it in a corner.
My jeep has put down two streaks before, but I do not have an LSD. But usually it puts down one as can be proven by my bald right rear tire. Every LSD I have ever seen will turn the wheel in the same direction if it is in good operating condition and has friction modifier if needed. That is the whole point to turn, if the other wheel loses traction. So if you spin the other way your clutch packs are gone, because the clutches are not holding. However if your brakes are dragging it could cause it not to turn or maybe turn a little in the opposite direction. |
#38 | |
#39 | |
Jeep Addict
No not at all, you will be just fine. Most gear oils today (i.e. valvoline, mobil 1, etc) all have the friction modifiers in them, but are not only for LSD rear ends.
'93 YJ (Under Construction) Previous Jeeps: '83 CJ7 '92 YJ '00 XJ '99 TJ '05 TJ Rubicon |
#40 | |
The XJ
#41 | |
You also have to remember that clutch-type limited slips respond to driveshaft torque. I do know that clutch-type LSDs always have both axle shafts at least slightly coupled, but it is possible to build a LSD so that in a "no torque" situation it behaves very much like an open diff. That means, with no torque applied through DS, both wheels won't turn in thh same direction if they are up in the air (or even if the other tire is on the ground and the other up in teh air, tranny in neutral). Then, when torque is applied through the DS, the clutch packs are pressed tighter together and splitting the torque to both wheels. I don't know what are the static spring loads for teh clutch packs on the F8.8, the D35 or the two different LSD units I had in my Opel Omegas. I do know however that the clutch packs in the F8.8 have considerably more static preload on the packs than on my Opel rear-ends (both had independent rear suspension). More static preload automatically results in both wheels turning the same direction even under no load (ie. both wheels in the air and turning the other wheel). It doesn't, however, tell how tightly the packs are pressed together under load. IIRC, both F8.8 and D35 trac-lok LSDs are ~25% locking. The ones on my Opel where ~50% locking, and you can definitely feel the difference between those while driving. Neither of the Opel diffs turned the wheels in same direction if I tried the method - not once. My Ford 8.8 did it every time I tried (I never had it mounted under my XJ with the LSD), the D35 did it sometimes but not every time.
#42 |
I still stand by what I say, however I should have said my experience is with Clutch type, from WIKI. So according to this, the wheels should turn together if off the ground. Torsen, torque sensing, viscous and others may be different
The clutch type LSD responds to driveshaft torque. The more driveshaft input torque present, the harder the clutches are pressed together, and thus the more closely the drive wheels are coupled to each other. With no / little input torque (trailing throttle / gearbox in neutral / main clutch depressed) the drive wheels are still coupled somewhat as the clutches are always in contact to some degree, producing friction. The amount of preload (hence static coupling) on the clutches is determined by the general condition (wear) of the clutches and by how tightly they are shimmed. So the moral of the story is if you have a clutch type and the wheels don't turn the same way, then you have a very worn or low locking LSD. |
#43 | |
Is there an advantage to having an LSD?
1998 Cherokee 4.0L 1999 Grand Cherokee Limited 4.7L |
#44 | |
OR you have a very low-locking limited slip when there is no torque applied through DS ..in other words, this kind of LSD would have very low static (pre)load on the clutch packs. But having very low static (pre)load on the clutch packs doesn't necessarily mean the limited slip diff is of low- locking type when torque is applied.Like I said, never did the tires spin the same direction on my Opel Omegas, but the limited slip diffs worked absolutely FLAWLESSLY on every possible situation where I put them. Dry asphalt, wet asphalt, sand, mud, snow, ice, other tire on ice other on asphalt, driving straight, cornering.. every possible situation. Like I already wrote, they both were 50% locking. I'm not saying all LSDs behave like that - my F8.8 was EXACTLY like you wrote. My D35 was like that sometimes (don't ask me why?). My Opel rear-ends were never like that, one of my friends has a limited slip on his (E30- body) BMW 320i, it acts just like my Opel diffs. Two other friends had limited slips on their Chrysler LeBarons (early 80s models), both wheels turned the same direction. It all depends on the design, so I guess one could say we both are correct, and we both are wrong, depending on how you look at it ![]()
#45 | |
Youngin'
-Brendan
