Quantcast Is this a LSD? *PIC* - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Is this a LSD? *PIC*
Old 01-01-2008, 09:40 PM   #16
SilverSpy0
1994 XJ Cherokee
Originally Posted by CJ7-Tim
Yes, you can spin one tire by hand. The other tire will turn same direction if you have a limited slip.
Or, if you had spinners on, only 1 would be moving. 1 would be stopped. The illusion wins.
All stock '94 XJ
Needs love. Give me tips on replacing floorboards...
SilverSpy0 is offline   Reply With Quote
Old 01-03-2008, 10:13 AM   #17
mtl4life
1995 XJ Cherokee
Originally Posted by Matt Gertsch
That appears to be a ULSD.
What is a ULSD?
- 1995 Cherokee SE 4X4
- 2004 Grand Cherokee Laredo 4X4
mtl4life is offline   Reply With Quote
Old 01-03-2008, 10:16 AM   #18
MBJR9
I was kinda wondering the same thing. Only thing that comes to mind is ultra low sulfur diesel or maybe un limited slip differential, meaing that it's a peg leg.
The XJ
1996 XJ Sport, 4.0L HO I6, AX15 5 Speed, NP231, Dana 30/35, Flareless
The Daily Driver
2004 Ram 1500, 5.7L Hemi V8, 545RFE 5 Speed Auto, NP241, Chrysler 8.0/Chrysler 9.25, 10mpg
MBJR9 is offline   Reply With Quote
Old 01-03-2008, 10:22 AM   #19
RogueXJ
1997 XJ Cherokee
a good way to tell is if you jack up the rear end and spin one tire. If the other tire spins thte opposite way you have open, if it spins you have LSD or a locker. To findout if its LSD (usually is if its jsut factory) you jack up only one wheel then try to spin the tire. THis will require some significant effort but if you are able to spin the tire and the other side is grounded....you have LSD. lol or your locker is broken. If both tires remain stationary...congrats you have lockers you lucky dog.
RogueXJ is offline   Reply With Quote
Old 01-03-2008, 10:40 AM   #20
Timo_90xj
Timo_90xj's Avatar
1990 XJ Cherokee
Originally Posted by n20jeep
yea you can...most of the time you can jack up the rear end and spin one tire....if the other one spins the same direction then it probably has an LSD. if it spins the oppisite direction then its an open diff
The problem is, it doesn't always work that way at all. I've had three vehicles with clutch- based LSDs, all of them working properly, and none of them had consistent results when tested like that.
The only way knowing if you have LSD is to pop the cover and look at the carrier, or to measure it the FSM way. ..or do tight figure-8s at slow speed on tarmac and see if the inside tire "hops" a little.
1998 Grand Cherokee 5.9 LX, 100k miles, 1.75" BB, 32 x 11.50 BFG MT KM2s, custom- fabbed bumpers etc..
http://www.jeepforum.com/forum/f13/daily-driver-5-9-build-thread-bumpers-tube-rockers-etc-1222317/
***Under construction***
1990 XJ (4-door), 4.0 I6, AW4, NP242, PBR 42" tires, Unimog portal axles, 110" WB, full cage + uniframe completely rebuilt, front 3-link + panhard / double triangulated 4-link rear, etc...
http://www.jeepforum.com/forum/f11/hybrid-cage-build-exo-cage-internal-973910/
Timo_90xj is offline   Reply With Quote
Old 01-03-2008, 10:43 AM   #21
1996xj
How about doing a burnout and seeing if there are one or two streaks on the ground.
1=the one wheel wonder
2=LSD or locker
1996xj
3" Rough Country Lift, 3in shackles, 3 RC shocks, 31" BFG ATs, 2 KCs, Lighted Roofrack, Soft 8s, TC drop, Custom oil leak deflector.
If only i could get a set of tires to last me 10,000Miles
Originally Posted by toates89
i am just gunna drive around in 4lo on dry streets, and peel out
Originally Posted by 4.0H.O.XJ
I once got a ticket for jerking while driving it. The cop wouldnt let me use his pen to sign the ticket.
1996xj is offline   Reply With Quote
Old 01-03-2008, 11:38 AM   #22
Haleyes
Originally Posted by mtl4life
500% sure that is an OPEN differential.
Get the rear off of the ground. Spin one tire, the other will spin the oposite direction.
If it had a LS it both tires would spin in the same direction.
Hale
96' XJ, 33's and 4.88's
http://img.photobucket.com/albums/v6...d/100_5140.jpg
Haleyes is offline   Reply With Quote
Old 01-03-2008, 11:46 AM   #23
bmyohn
Youngin'
bmyohn's Avatar
here is my limited slip out of my 8.8"
2001 Dodge Ram 2500 SLT 4x4
5.9L Cummins Turbo Diesel
"The Tow Rig"
1988 Jeep Comanche
2.5L 4cyl - 4 speed manual
2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker
6.5" TnT Customs Longarm Kitl Ford 8.8" w/ disc brakes l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l 35" Maxxis Bighorns l 15 x 8 Cragar Black Soft 8s (4" BS) l High Clearance Shock Mounts l 4 - BAJA off road lights l TnT Customs D30 Truss l Hidden Hitch l ARB Front Diff Cover l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l HP D30 l JKS Mini Skids and Sway Bar Brackets l TnT Customs OTK Steering
bmyohn is offline   Reply With Quote
Old 01-03-2008, 12:59 PM   #24
Timo_90xj
Timo_90xj's Avatar
1990 XJ Cherokee
Hale
Again, that does NOT always work!!!
Like I just wrote above, I've had three RWD vehicles with clutch- based LSDs that worked flawlessly, and NONE of them showed consistent results with that test...
Old 01-03-2008, 01:02 PM   #25
1996xj
Do the burnout test.
1996xj
Old 01-03-2008, 02:16 PM   #26
MBJR9
Personally, my favotive method . But I'm positive that's an open diff.
Bmyohn, the shaft the connects the set's of spiders in his diff. is straight, yours isn't. And there lies the difference.
The XJ
The Daily Driver
Old 01-03-2008, 02:25 PM   #27
mtl4life
1995 XJ Cherokee
Thanks for all the replies everyone. Now that it's verified that my diff is open, I have one other question. The fluid I used has friction modifiers in it. Will this cause any issues with an open differential?
Old 01-03-2008, 02:38 PM   #28
MBJR9
I don't believe it will cause an adverse effects, alot of times in clutch type posi units all it does is reduce chatter.
The XJ
The Daily Driver
Old 01-03-2008, 02:42 PM   #29
marlow
1990 XJ Cherokee
my mustang lays two very nice 315 sized lsd burnout marks and if you raise the back end and spin one wheel, the other often spins in the opposite direction. just and example of when the wheel spin method doesnt work
94 Ranger XLT - EFI 331, AOD, Dana 20, 4.10s, Trac-lok 8.8, 4" Suspension Lift, 3" Body Lift, 33x12.50s
90 XJ - 230k miles 4" Homemade Lift, 31" TSL's, Lots of Dents - sold
95 Mustang GT - Loves the nitrous
When in doubt - throttle it out.
marlow is offline   Reply With Quote
Old 01-03-2008, 02:44 PM   #30
wojtizzlator
1987 XJ Cherokee
tht looks like a regular open diff to me
Wojtek
"who needs paved roads when u have a jeep"
87 xj 6" long arm lift, 35's, 4.88 yukon gears, front detroit true trac
colorado jeep club member # 74
wojtizzlator is offline   Reply With Quote
Glock Forum
