Lower radiator support bracket. - JeepForum.com
post #1 of 12 Old 03-17-2012, 12:08 PM Thread Starter
JYPS
I am working on a 97 Cherokee Sport. It was hit on the left fender between the headlight and the steer tire. The radiator and transmission cooler are offset and bent. So is the metal bracket/ piece they sit on. Can the metal piece they sit on be unbolted off and replaced, or does it have to be cut off and rewelded in place.
Thanks Tommy Davis
JYPS is offline
post #2 of 12 Old 03-17-2012, 05:06 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Have any pictures of the metal piece ?
CJ7-Tim is offline
post #3 of 12 Old 03-17-2012, 05:31 PM
Azzy
The center piece where the rubber boots / radiator posts go?
IIRC (just had my rad out today) its welded in. Doesnt mean you couldnt go out to the junk yard, drill some spot welds and get a new one.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #4 of 12 Old 03-17-2012, 05:35 PM Thread Starter
JYPS
I do have pics, do not know how to post them on here. If you can guide me thru it, I can get them on.
JYPS is offline
post #5 of 12 Old 03-17-2012, 05:37 PM Thread Starter
JYPS
Azzy, you are describing the bracket I am talking about.
JYPS is offline
post #6 of 12 Old 03-17-2012, 06:33 PM
Carves
The dog thinks hes talking about the crossmember ...
Replacable yes ... but you need to be careful everything stays in alignment - while doing the work.
If you've had a bingle in the front corner ... you may find things are already out of square a bit.
Carves is offline
post #7 of 12 Old 03-17-2012, 06:44 PM Thread Starter
JYPS
The dog does know. That is it. Now, what would be the easiest way to get it off. I do not have a welder, just a hacksaw. Also, can it be drilled into to take bolts instead of welding it back on. I have limited tools and resources here at my house.
JYPS is offline
post #8 of 12 Old 03-17-2012, 10:13 PM
CJ7-Tim
CJ7-Tim's Avatar
You will have to drill, cut and grind metal to remove the cross member. You can temporarily bolt in the replacement for alignment and to drive slowly to whomever is going to weld it. The repairs must be welded. A trailer or tow dolly is probably a better idea than driving more than a mile or so. There are holes in the frame rails and the cross member that you use to line up the parts.
I replaced the cross member after this Cherokee tangled with a tree.
CJ7-Tim is offline
post #9 of 12 Old 03-17-2012, 10:14 PM
AZ Jeff
2014 JK Wrangler
Look at it this way---that part is more than just a bottom support for the radiator. It's the #1 crossmember for the "frame" of your vehicle, and ties the front of the frame "horns" together. In other words, it's structural.
The flanges are not really big enough to use bolts on, although if they were bigger, it could be bolted together. Since you either need to make the flanges bigger to use bolts or reattach like the factory did, both methods would require a welder.
In a nutshell, find a friend with a welder and tie it back together properly.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #10 of 12 Old 03-18-2012, 02:18 PM Thread Starter
JYPS
http://s1249.photobucket.com/albums/hh520/JYPS/
This is the only way I know how to post the pics of what I am talking about. I am taking the pics on my back, my feet sticking forward of the vehicle. Most of the damage is by the steering gearbox.
Any suggestions would be very helpful.
Tommy Davis
JYPS is offline
post #11 of 12 Old 03-18-2012, 02:56 PM Thread Starter
JYPS
CJ7-Tim:
Where can I buy a crossmember? I tried researching for one, and I keep coming up with the one around the transmission. I see in your picture, you have a new one.
Thanks Tommy
JYPS is offline
post #12 of 12 Old 03-18-2012, 05:52 PM
CJ7-Tim
CJ7-Tim's Avatar
Any Jeep Dealership should be able to order one. On-Line Jeep Dealerships offer a 30% discount off retail prices. See if your Dealership will match that.
Try - http://www.chryslerpartsdirect.com/
Jeep Part # 55174978 - BODY HARDWARE / RADIATOR SUPPORT / RADIATOR SUPPORT / Lower tie bar
CJ7-Tim is offline
What is the part where the radiator support bolts to on each side? 95cherokee33s XJ Cherokee Technical Forum 3 03-23-2011 06:17 AM
Fender Support Bracket Needed? Cherokeekid88 XJ/MJ Cherokee Non-Technical Forum 5 10-02-2009 04:34 AM
Repair Plastic Support for Radiator Electric Fan gmshades XJ Cherokee Technical Forum 2 04-10-2009 08:24 PM
Lower control arm bracket and steering cliffbong732 XJ Cherokee Technical Forum 3 02-12-2009 02:46 PM
Lower support arms removal Kenny 96 XJ XJ Cherokee Technical Forum 1 09-29-2003 02:43 PM
