lower ball joint problem - JeepForum.com
post #1 of 3 Old 08-06-2009, 11:04 PM Thread Starter
jeepnphreak
1989 XJ Cherokee
OK
Iam in the process of replacing the ball joints. all smooth except for one small hicup. part K3137t moog lower ball joint.
the Zerx fitting is too tall, the U-joint from the axle hits the zerx. So much to the point of the axle will not turn.
The ball joint IS pressed to the lip that it is susposed to and the zerx is threaded all the way as far as I can get it in to the ball joint. thus I do not belive that I screwed up the install.
Does any one have any ideas to remedy this problem?
1989 XJ, 5spd, np231 with bjconversion SYE , re3.5, 33x12.5r15 BFgoodrich ATS, D30 F, Dana 44 from 87 with 4.56s, Custom front bumper.
94 yj: stock everything and 4 angry squarrels under the hood.
jeepnphreak is offline
post #2 of 3 Old 08-06-2009, 11:31 PM
jeep95xj
1995 XJ Cherokee
The ball joint should have come with a blank block off. The grease it up, remove the fitting, and screw the flat top fitting in. You cant grease it once the axle is back in anyway. It's pretty much a really low profile bolt that replaces the grease fitting.
jeep95xj is offline
post #3 of 3 Old 08-07-2009, 08:58 AM Thread Starter
jeepnphreak
1989 XJ Cherokee
Thanks, Ill have to track down two of the blank block off. My ball joints only came with the zerx fittings...
tricks for lower ball joint removal please... 96yeepster XJ Cherokee Technical Forum 21 08-29-2013 03:01 PM
Stubborn lower ball joint castle nut Jeeprs89 XJ Cherokee Technical Forum 4 07-14-2009 10:54 PM
Can't get out lower Ball joint CharlieMopps XJ Cherokee Technical Forum 23 10-22-2008 05:20 PM
Lower Ball joint. nujeepguy XJ Cherokee Technical Forum 7 02-17-2008 07:43 PM
Greasable lower ball joint? NotMatt XJ Cherokee Technical Forum 3 02-17-2004 11:04 PM
