Lower Ball joint. - JeepForum.com
post #1 of 8 Old 02-16-2008, 03:37 PM Thread Starter
nujeepguy
1997 XJ Cherokee
Lower Ball joint.
about 10 months ago I Changed the front axle u-joints and put anti-seize on all the hardware so if when i needed to get back at the axle nut,hub bolts etc. it would be a breeze. Well... I got a lower ball joint that needs to be replaced on the pass. side. I was wondering how hard they are to remove. do i need to remove the upper ball joint. i understand they are pressed in so are they f##% ers to get out? I am thinking of letting a mechanic do it in case they are absolutely seized in there. I do my own work usually but they do look like a job that i am not sure if i want to tackle. someone tell me if they are bad or easy. Any harder than the u-joints.?
nujeepguy is offline
post #2 of 8 Old 02-16-2008, 05:13 PM
Sierra Drifter
They are fairly easy to change, however there is a lot of work to get to them. That's why its so expensive to have it done at a shop. You have to remove the knuckle, rent or buy a ball joint hand press. It looks like a large C clamp and it pushes the ball joints in and/or out of the steering knuckle.
You will have to remove the upper ball joint so that you can change the lower one. The long threaded rod has to pass through the upper ball joint hole to press in the lower one.
2001 XJ RE 5.5 ED w/T&T Y-link longarm, 37" MTR's, D44/D60, ARB's, Rubicon Tcase, and all the usual junk.
Axle swaps & build thread:
Sierra Drifter is offline
post #3 of 8 Old 02-17-2008, 06:10 AM Thread Starter
nujeepguy
1997 XJ Cherokee
yeah, that's what I thought. I am not fond of having to hand over $$$$ to another person for something I can do myself. Just wondering if there is a full write up on the job. never had the knuckle off before. I bought a u-joint hand press which is the same thing as the tool in the photo but it doesn't have all the end pieces (removal adapters and receiver tubes)to fit over different size press outs. Do you think I should be able to rig something up with it?
post #4 of 8 Old 02-17-2008, 11:34 AM
Sierra Drifter
This picture above is a Dana 44 knuckle, on the Dana 30 the ball joints press into the inner 'C' rather than the steering knuckle. The tool is the same, the process is very similar. I would rent the press from Autozone, I wouldn't try and 'rig' anything up.
Write ups here:
http://www.madxj.com/MADXJ/technical...balljoints.htm
http://www.moabjeeper.com/articles/t...?articleID=222
http://www.popularmechanics.com/how_...e/1888732.html
post #5 of 8 Old 02-17-2008, 01:13 PM
HeepToJeep
1982 CJ8
The best place to purchase them is Rockauto.com, their Moog parts are 1/2 the price of everyone else and come with a lifetime warranty. Soaking them with penetrating oil for a few days prior makes removal a hell of a lot easier and if you aren't strapped for cash I'd definately suggest doing them all at the same time. A side note on loaner tools that require a deposit, do so with cash if at all possible....otherwise it takes up to ten business days to refund your credit or debit card.
Wm
HeepToJeep is offline
post #6 of 8 Old 02-17-2008, 01:40 PM
95_TSi_AWD
1991 XJ Cherokee
if you call around you can probably find a shop that will press the joints in and out for you if you bring the knuckle to them.
EDIT sorry never did xj joints i was just going off other trucks i've done. but this won't work for an xj
95_TSi_AWD is offline
post #7 of 8 Old 02-17-2008, 05:32 PM
red_01_xj
XJ Cherokee
yep you might as well do both upper and lower
2000 RED XJ
4.5" RE Super Flex, Mono Tubes, 31" BFG AT, WJ seats Front and rear, Boxed Rocker panels with Rails, Upcountry Junkyard Special, homemade front bumper, C4x4 rear bumper and swing out, low profile light bar, jks disconects, farmboy tail lights lebaron hood vents, teraflex sye, Dana 30 HP with factory 4.56 disco converted to solid shafts, with powertrax, Dana 44 with detriot true trac with 4.56 and ZJ disc brakes...and the best part is all of my major mods are used
Ebay items
red_01_xj is offline
post #8 of 8 Old 02-17-2008, 07:43 PM
AZ Jeff
2014 JK Wrangler
The ball joints are NOT in the knuckle. They are in the YOKE on the END of the axle housing.
Owing to this, to change ball joints, you HAVE to use the special tool ON THE CAR.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
tricks for lower ball joint removal please... 96yeepster XJ Cherokee Technical Forum 21 08-29-2013 03:01 PM
lower ball joint problem jeepnphreak XJ Cherokee Technical Forum 2 08-07-2009 08:58 AM
Stubborn lower ball joint castle nut Jeeprs89 XJ Cherokee Technical Forum 4 07-14-2009 10:54 PM
Can't get out lower Ball joint CharlieMopps XJ Cherokee Technical Forum 23 10-22-2008 05:20 PM
Greasable lower ball joint? NotMatt XJ Cherokee Technical Forum 3 02-17-2004 11:04 PM
