Low voltage when A/C is on. - Page 2 - JeepForum.com
post #16 of 25 Old 08-10-2013, 10:23 PM
sAe23
1995 XJ Cherokee
Originally Posted by RamboPants View Post
[snip]
I think whatever causes my low idle is causing my voltage problem.
[snip]
Um, maybe this info should have been part of your original post?!?
How slow DOES it idle?
sAe23 is offline
post #17 of 25 Old 08-11-2013, 06:09 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
A bad TPS and dirty throttle body can cause low idle, along with a bad oxygen sensor.
Click on th link in my sig and do # 11, and 5.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #18 of 25 Old 08-24-2013, 09:02 AM Thread Starter
RamboPants
1987 XJ Cherokee
Replacing the o2 and knock sensor today and I'm gonna try your suggestions. I'll post my results and thanks for the help.
RamboPants is offline
post #19 of 25 Old 08-24-2013, 09:29 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Don't waste your money on the knock sensor. Causes no driveability issues.
Do 11 and 5 yet?
post #20 of 25 Old 08-24-2013, 12:28 PM Thread Starter
RamboPants
1987 XJ Cherokee
Already wasted the $ on the knock sensor so i just put it in anyway along with the o2 sensor. I did #5 and #11 and everything was good, so i disconnected the vac hose from the egr solenoid and it runs perfect with the AC on, it idles a tad high in park but in gear its runs great and doesn't bog down like it was before. I'm guessing it wasn't electrical it was just the engine running weak possibly from a bad egr solenoid? Does that make sense to you?
post #21 of 25 Old 08-24-2013, 12:51 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Could be the problem was the EGR solenoid. 2nd one on the forums this week.
Have you adjusted the engine side of your TPS after cleaning the throttle body and IAC?
post #22 of 25 Old 08-25-2013, 09:53 AM Thread Starter
RamboPants
1987 XJ Cherokee
Yes I checked both and made sure the wires were not losing contact with each other by back probing on each side of the connectors trans and engine.
post #23 of 25 Old 08-26-2013, 05:52 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Make sure your intake manifold bolts haven't loosened up and be sure the CCV harness is in good shape. Valve cover grommets, piping, hoses, connectors.
post #24 of 25 Old 08-28-2013, 07:32 PM Thread Starter
RamboPants
1987 XJ Cherokee
it was on 0 some how
post #25 of 25 Old 09-02-2013, 05:01 AM
danblue636
It's the belt tension...or it needs to be replaced
danblue636 is offline
