Quantcast Low/Crawl ratio questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Low/Crawl ratio questions
Old 03-19-2005, 10:49 PM   #1
wrecked
I went wheelin on thursday and had a great time. No problem for me at all. The girl I went with was driving an '88(I believe) toyota. She offered to let me drive hers over this little hill thing that I didnt think it could go through(and it didnt). Popped it into 4L and low on the tranny and the yota crawled. Seriously it hardly even moved. It was the first time I have ever been impressed by a "yota."
With my jeep, I cant notice a difference between 4hi and 4low, it doesnt matter what I shift the tranny to. Shouldnt mine be about the same. Time to get my transfer case worked on?
1990 Cherokee Limited 4door, 7 inch RE lift, 35x14.5 SS Bogger, Ford 9" with spool and 4.88 gears(full width)
Hp 44 with 4.88 gears(full width), AW Shifting unit, On board Air, and a bit o' body armor.
1990 Cherokee Laredo 2door, 3 inch Old Man Emu Lift, Wildcat EXT 31x11.5 tires on 15x8 daytona rims(offroad and daily driving), Futura 31x10.5 on 15x8 American racing rims(long traveling)
wrecked is offline   Reply With Quote
Old 03-19-2005, 11:42 PM   #2
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
There is a way to wire in a Override switch into the older AW4 trans. It will not hold first on it's own. Check the Tech/FAQ sticky for the links to it.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 03-20-2005, 12:38 AM   #3
Rock Kustoms
you should feel a huge diff between 4 hi and 4 lo, 4 lo gears your drivetrain down to almost 1/3 of 4 hi.......
i know with my 5 speed 1st gear in hi is about the same "feeling" as 3rd in lo
Rock Kustoms is offline   Reply With Quote
Old 03-20-2005, 12:56 AM   #4
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Mine starts off in 2nd when I shift into 4 low. I think they all do that. This is the major drawback with the AW4.
"'Did you ever wonder why we had to run for shelter when the promise of a brave new world unfurled beneath a clear blue sky? "
Roger Waters
Matt Gertsch is offline   Reply With Quote
Old 03-20-2005, 09:27 AM   #5
Blue XJ
1988 MJ Comanche
Mine doesn't, but I usually leave it in 1-2 when I am in 4low. That migt be why, it holds 1st forever that way.
'88 MJ
Blue Jeep Club Member #72
| 4.6L Stroker | AW4 | 6.5" RK Long Arm Kit | 35" TruXus MT's | HP30, 4.56, ARB, Alloys, Lockouts | C8.25, 4.56, ARB, Alloy Shafts, Disk Brakes | Warn XD9000i | Interior Cage |
Blue XJ is offline   Reply With Quote
Old 03-20-2005, 01:33 PM   #6
wrecked
So am I looking at a transmission problem or a transfer case problem?
My '90 laredo has an automatic transmission. Im not sure which one though. Her toyota was automatic also.
I was planning on taking the Jeep into the shop to have some brake work done on my day off. Maybe I should get the other stuff looked at as well(and spend alot of money).
Old 03-20-2005, 05:41 PM   #7
Matt Gertsch
www.lp.org
Some rigs just need more of the long and skinny.
Roger Waters
Old 03-20-2005, 05:54 PM   #8
Scrub
Sounds like it would be a T-Case problem, I Can Deffinatly feel the difference in my Xj when its in low range.
As a side note your Auto Tranny Is the AW4
-Matt-
[SIZE=1][FONT=Tahoma]89 XJ 4door - Limited - AW4 - NP231 - 180K - 31's - About 5" Lift - Trimmed
[COLOR=Red]Red Jeep Club Member [B]#275[/B][/COLOR][/SIZE][/FONT]
Scrub is offline   Reply With Quote
Old 03-20-2005, 06:09 PM   #9
ChiTown'01XJ
There is a huge difference between 4hi and low on my '01. In 4hi it feels just like 2wd. 4low and in 1st gear is a different story, it "pull" forward when you're stopped, and engine breaking is much more effective.
[COLOR=blue]Blue Jeep Club Member #73[/COLOR]
'01 XJ Sport
235/75/15 BFG All Terrain T/A KO, C4X4 tow hooks, rear hitch, 2 x 55 Bosch Lights, Cobra 19+ (waiting on antenna)
[B]"Let's do it in the dirt"[/B]
ChiTown'01XJ is offline   Reply With Quote
Old 03-20-2005, 10:36 PM   #10
BrunoS
here's the Transfer case skinny lowdown:
If you have a manual, use 4LO and 2nd gear to start off. 4LO and 1st are way too short for gearing, the peak output stress at all points of power train are about met and this is where you break parts. Use 2nd gear to start off in if you can.
If you have an automatic, this is why in 4LO it starts in 2nd. Per the forum, there is a sticky on how to install a bypass wire and switch to allow the tranny a 1st gear start. I wouldn't recomend it, per the above manual tranny info, for the same reasons.
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline   Reply With Quote
Old 03-20-2005, 10:43 PM   #11
jeeponly
What are you basing this on? I always run mine in 4LO and the tranny in 1st unless I'm crossing a mud hole, which is rare. I haven't had a problem with powertrain breakage.
Spring project:
D44 front
5.13s, Detroits, alloys, hi-steer, blah, blah, blah.....
jeeponly is offline   Reply With Quote
Glock Forum
