Low Coolant light constantly flashes - JeepForum.com
post #1 of 7 Old 12-05-2009, 10:17 AM Thread Starter
medicmandan
medicmandan's Avatar
Low washer fluid light constantly flashes
Every time I hit a bump or take a sharp corner. While I was test driving XJ's over the summer every one I drove did this.
Is it a bad sensor? A quick look at the wiring doesn't show anything obvious.
Make that the low washer fluid light.
medicmandan is offline
post #2 of 7 Old 12-05-2009, 10:20 AM
troys96xj
Never heard of that problem.
troys96xj is offline
post #3 of 7 Old 12-05-2009, 10:23 AM Thread Starter
medicmandan
Haven't had any caffeine this morning. Meant low washer fluid light.
post #4 of 7 Old 12-05-2009, 01:12 PM
ehall
1991 XJ Cherokee
the floats are bad for getting waterlogged, either buy a NEW one from the dealer or disconnect the sensor wires from the top of the float
ehall is offline
post #5 of 7 Old 12-05-2009, 01:14 PM
black94xj
1994 XJ Cherokee
yeah the float is cheap stryofoam that gets saturated i got a new one from the junkyard
--NJ Jeeper--
|_____0000_
l[__][_\\____\___ -94 XJ- 6.5 Rustys, 35 BFG
l--____--|[]lllllll[]| 8.8 rear, KC Daylighters
(o)_)--(o)_)-0-)_)
Jeeps eat wallets
black94xj is offline
post #6 of 7 Old 12-05-2009, 01:27 PM
ehall
1991 XJ Cherokee
junkyard units are short-term fix at best, they are either just as waterlogged or will be shortly.
ehall is offline
post #7 of 7 Old 12-05-2009, 03:33 PM
USMC_XJ
2003 WJ
Just pull the wiring. I did on mine because it was the same problem. When it is low, you will know.
1994 Cherokee Sport - 4.0 HO - AW4 - 4WD
Originally Posted by Rob99
The next time you want to tell a story but not get people's opinions, rather than post it on an internet forum, open up Microsoft Word, type your story there, then click on the little X in the top right corner and then hit yourself in the head with a sledge hammer.
Originally Posted by bigsquat
If he finds the yj section im putting round headlights on mine.
USMC_XJ is offline
'01 XJ CEL flashes 12 times and goes out colt933 XJ Cherokee Technical Forum 8 09-01-2009 04:13 PM
Check Engine light after coolant flush rickster70 MJ Comanche Technical Forum 2 01-22-2009 03:22 PM
Fan Kicks On And Off Constantly??? J_Mayle XJ Cherokee Technical Forum 4 01-16-2008 09:58 PM
coolant light dieselcrackel XJ Cherokee Technical Forum 1 12-31-2007 05:22 PM
engine fan constantly on notreve76 XJ Cherokee Technical Forum 8 03-07-2007 12:42 AM
