Low compression one cylinder? - JeepForum.com
post #1 of 2 Old 07-26-2002, 06:45 AM Thread Starter
jaybyrd
jaybyrd's Avatar
Bad exhaust lobe on camshaft???????????
90 psi on 1st cylinder of I6 4.0L, all the rest are 120 psi.
Haynes says no more than 30 psi variance and it runs well, just looking for ideas into the root cause.
jaybyrd is offline
post #2 of 2 Old 08-15-2002, 07:50 PM
94gclimited
If you haven't yet try some Restore. I have used this stuff in my Jeep with 120k and it made a difference in power. I've heard of people who had a couple cylinders with so bad of compression the engine wouldn't stay running and a can of this stuff fixed it. For about 7 bucks its worth a try.
Jason
94gclimited is offline
Low compression in one cylinder. Lone Star XJ XJ Cherokee Technical Forum 6 09-28-2010 10:15 AM
clutch master cylinder or slave cylinder? baba1 XJ Cherokee Technical Forum 9 12-15-2009 12:34 PM
Too much compression? limited XJ Cherokee Technical Forum 5 07-16-2008 12:39 PM
4.0 compression lifted92xj XJ Cherokee Technical Forum 8 11-27-2007 09:10 AM
cylinder compression technical question. jaybyrd XJ Cherokee Technical Forum 3 08-13-2002 10:52 PM
