Quantcast Loud Squeel, New belt, water pump and thermostat - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Loud Squeel, New belt, water pump and thermostat
Old 11-20-2009, 10:40 AM   #1
logand20
1998 FSJ Cherokee
Hello all - I got some great advice a couple weeks ago because i had a loud grinding and squeeling coming from the engine.
I was told to replace the water pump. It was wrecked!
I replaced the water pump, thermostat and serpentine belt and the jeep is finally running.
The new issue is that it is running fine without A/C or Heat but as soon as i turn either on there is a screeech like no other.
What now? Alternator? A/C?
98 Jeep Cherokee 4.0 4x4
160k
logand20 is offline   Reply With Quote
Old 11-20-2009, 01:25 PM   #2
CJ7-Tim
Go Jeepin
CJ7-Tim's Avatar
Tighten the serpentine fan belt. XJ (not FSJ) Cherokees like the belt really tight.
FOR SALE: Wide Track CJ-7 Dana 44 rear axle.
PM me for details
A Government big enough to give you everything you want, is a Government big enough to take from you
everything you have. The course of history shows that as a Government grows, Liberty decreases.
CJ7-Tim is offline   Reply With Quote
Old 11-20-2009, 01:59 PM   #3
JeepGirl720
1991 XJ Cherokee
You really want to tighten that belt... I had a horrible squeal coming from mine, the belt needs to be really tight
JeepGirl720 is offline   Reply With Quote
Old 11-20-2009, 02:29 PM   #4
hubs97xj
1997 XJ Cherokee
Krikit II! Belt tension is posted around here somewhere as well. Also, a new belt will stretch (there is a tension for a "new" belt [under 15 mins runtime] and another for "used" belts) a little, so what may have been good tension is just on the edge, and running the compressor is enough to make that lovely squeal.
hubs97xj is offline   Reply With Quote
Old 11-20-2009, 03:09 PM   #5
XJmaine97
1997 XJ Cherokee
tighten tighten tighten tighten...seriously, just keep tightening it
XJmaine97 is offline   Reply With Quote
Old 11-21-2009, 02:34 AM   #6
Mikes99XJ
You'll be dumbfounded as to how tight the belt needs to be not to squeek when the accessories are on such as loads from A/C, alternator, and power steering.. Good luck.. Dont be Skeered just keep tightening it.
Mikes99XJ is offline   Reply With Quote
Old 11-21-2009, 02:48 PM   #7
Johnny1953
Keep it as tight as you can with out breaking it.
Johnny1953 is offline   Reply With Quote
Old 11-21-2009, 07:34 PM   #8
98GooseXJ14
98GooseXJ14's Avatar
I have a decal on my jeep that says aint skeered anyway yeah I am having this same issue so thanks for the helpful info to me to and for getting this up before me. Mine had a new belt when I bought it and does the same thing.
98GooseXJ14 is offline   Reply With Quote
Glock Forum
