Quantcast Loud Squeal & Loud Leaf Springs - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Loud Squeal & Loud Leaf Springs
GR8TOPS Introduces the Exogate HD Tire CarrierRUBICON EXPRESS Lift Kits and Accessories Available at BasSpartan Lockers FREE SHIPPING Excellent Prices
Old 03-17-2008, 08:24 AM   #1
XxpeditionxJ
Hey guys, got a new one for yah. I am having a tough time with my new leaf springs. When I installed my 2.5" leaf from RE they have been squeaking non-stop. I have used WD40, PB, a few other things. What can I do to get them to stop? It is very annoying and draws negative attention.
Also, for a month now I have noticed when I pull up to a stop and take off there is a squeal from underneath my jeep. It only does it at low RPMS and only on take off from a stop. I can't tell if it is coming from the tranny, bearings, front diff. Have any of you experienced this? It almost sounds like a lower pitched belt squeal, but its not coming from the engine bay.
[COLOR="Blue"][COLOR="Red"]Flame Red [/COLOR]2000 Jeep XJ. I6-4.0 Powertec. Dana 30 FE. Chrysl 8.25 RE. NP231 xfer. 245x75x16 on Rubicon Wheels. K&N Cold Air Intake. Magnaflow High Performance Cat. Flowmaster 40 Series. Stuff..[/COLOR]
XxpeditionxJ is offline   Reply With Quote
Old 03-17-2008, 08:59 PM   #2
XxpeditionxJ
Anyone......
Old 03-17-2008, 10:55 PM   #3
89warwagon
1989 XJ Cherokee
my R.E leaves are noisey aswell.
My solution is going to be to jack the rear end up and let the axle hang so the leaf is unloaded which will allow easy access in between the leaves.Break out the grease gun with needle tip and grease the leaves and the pads..... or sliders as some call them.
89 xj 5.5 rubicon express,34" swamper ltb's
89warwagon is offline   Reply With Quote
Old 03-20-2008, 08:19 AM   #4
XxpeditionxJ
Thanks. I will try that. I will have it jacked up inmy garage anyway for other work that needs to be done. I am riding my motorcycle right now, so I can take my time.
DO any of you know of the axle/ whatever noise this is in my front end?
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
