Loud rear axle normal - JeepForum.com
post #1 of 12 Old 12-10-2005, 07:56 PM Thread Starter
Vaj
I was checking out a 93 Cherokee yesterday and something I noticed while driving it around was that the rear axle was quite loud. The owner had the axle replaced with a used rear axle a few months ago. The owner told me that he noticed the noise more after the axle was replaced. Is it pretty normal to hear noise from it inside the cabin?
Vaj is offline
post #2 of 12 Old 12-10-2005, 08:04 PM
XJohnnyC
XJohnnyC's Avatar
The used rear axle could have a bad axle bearing or pinion bearing. But check to see if it's got gear oil in it.
XJohnnyC is offline
post #3 of 12 Old 12-10-2005, 08:09 PM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
What does it sound like? I had a hard spot in a brake drum and it sounded like I had an owl on my rear axle. It kinda' made a hoo-hoo-hoo noise.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #4 of 12 Old 12-11-2005, 01:48 AM Thread Starter
Vaj
It's basically just a lower pitched hum that raises and lowers with vehicle speed. It wasn't an overwhelming noise or anything, but I'm also not used to driving a Jeep at all, and they seem to be fairly noisy in the cabin anyways. It may be nothing, but if I end up buying it I'll be getting a mech. inspection done and I'll get them to check it out. Thanks for the replies.
Vaj is offline
post #5 of 12 Old 12-11-2005, 01:26 PM
Matt Gertsch
www.lp.org
If you're not used to a Cherokee, it may be a normal sound. They do tend to make a little more noise that the average car. Really though, use your best judgement, if something sounds obviously wrong, don't buy it. There are plenty of XJs out there, just keep shopping. The right one will find you.
post #6 of 12 Old 12-17-2005, 09:15 AM Thread Starter
Vaj
Well I had it checked out and there are some serious problems in the rear end. The repairs added up to over $2300!!(A few minor repairs to the rest of the truck included) The search goes on............
Vaj is offline
post #7 of 12 Old 12-17-2005, 09:51 AM
ki1022
You could buy a whole new rear end for less than that
94' XJ
ki1022 is offline
post #8 of 12 Old 12-17-2005, 07:53 PM
XJohnnyC
XJohnnyC's Avatar
Yeah, can you break down that $2300 for us? Curious minds want to know.
XJohnnyC is offline
post #9 of 12 Old 12-17-2005, 09:29 PM
98SportDrvr
98SportDrvr's Avatar
....... for a rearend fix??? what you do, go to the dealer for a quote? i would definitly put money on the pinion bearing being worn out or bad for that sound. mine has a nice little wine on acceleration and coasting that gets worse some days and less on others. i know what it is and know what caused it. rebuilt my rearend bout a year and a half ago and bout 3 weeks later it started. if ya don't set that thing up just right or dont break it in properly(yes there is a proper way to wear in the diff) it will start premature wear which will stay till ya fix it. trust me if that shop wants 2300+- for that fix tell them where they can put that estimate... any reputable offroad shop can redo a diff for a lot less/ up to a grand..
oh yea and 2300 bux for a fix they are gonna charge ya for new seals, an arse load of labor and maby a new bearing or two. and if they really wanna rip you off they will tell you the ring and pinion need replacing because the bearing were bad and the gears are now worn out(BS!!!).. they will screw ya in nothing flat.
used to have my project jeep.... had to sell her and now i just dream of the future.
98SportDrvr is offline
post #10 of 12 Old 12-19-2005, 08:43 PM Thread Starter
Vaj
It was around 1300 in parts + 13 hours in labor at $75 an hour. There was a few things like a new thermostat, some pitman arm?, and ebrake piece, a wobbling rear tire, and something else included as well.
Just to be clear, no one was being ripped off here. This was a pre-purchase inspection. Nobody was forced into getting this stuff done. The guy took a guess at what was wrong with the rear end, and gave an estimate.
Vaj is offline
post #11 of 12 Old 12-19-2005, 11:15 PM
lockinup
I bought my 93 xj for $2000. Still runs fine.
lockinup is offline
post #12 of 12 Old 12-20-2005, 12:31 AM
XJ4oh
1997 XJ Cherokee
Thats highway robbery man! Ask someone on here how long it takes to swap an axle on an XJ, and they will tell you half a day with the right tools.. And the shop has the right tools, plus a lift. Thats total BS. Did you take it to a Jeep dealer? If so thats why.. Definatly keep looking.
'97 XJ... 4.0 4x4 AW4. 2" budget boost w/t-case drop.
31x10.5 Cooper Discoverer ST's on 15x7 Cragar Soft 8's.
Intake, Ported TB, TB spacer, Super 40 Flowmaster.
Baja Aux. Lighting.
Green Jeep Club #185, Nowhere to Wheel Jeep Club member #1
'04 WJ - Columbia Edition - 4.7HO 2WD
XJ4oh is offline
loud humming/grinding from front axle?? 96jeepster XJ Cherokee Technical Forum 2 01-12-2009 05:26 PM
Rear axle noise normal? itasor XJ Cherokee Technical Forum 9 06-10-2007 05:36 PM
front axle wheel hop is this normal MPETESS10 XJ Cherokee Technical Forum 4 02-16-2007 11:22 AM
How much rear end noise is 'normal'? tcb XJ Cherokee Technical Forum 1 10-06-2006 04:27 PM
Loud Fan on/off at Idle - Normal? ctcherokee17 XJ Cherokee Technical Forum 4 12-21-2005 05:24 PM
