loud popping noise from front side xj - JeepForum.com
post #1 of 18 Old 05-28-2013, 12:12 AM Thread Starter
kgovan32
I've been having a loud popping noise in the front right and left side whenever i'm braking in reverse, and sometimes normal braking. Doesn't do it while i turn and its more of a noise compared to a bad u-joint. i had a u-joint go out on me before so i know what that feels like but this is totally seperate feeling, i was thinkin blown shock i do have a 3.5" lift and horrible pro comp shocks on it. could that cause the problem?
also i have a really light metal sound coming from front right, sound like a loose cotter pin, could that be the u-joint?
i appreciate the help
kgovan32 is offline
post #2 of 18 Old 05-28-2013, 12:17 AM Thread Starter
kgovan32
also, i replaced LCA's with adjustable ones(Rubicon Express), adj. track bar(RE), ball joints (dana&spicer), hope that helps
kgovan32 is offline
post #3 of 18 Old 05-29-2013, 12:04 AM Thread Starter
kgovan32
also its a 89 xj 4wd solid axles
kgovan32 is offline
post #4 of 18 Old 05-29-2013, 05:37 AM
Hudson
Check your axle side trackbar mount. Make sure the bolt isn't loose and make sure the hole isn't wallowed out.
Live To Die. You're Not Going To Get Out Of This One Alive.
Build Thread - http://www.ausjeepoffroad.com/forum/showthread.php?t=121903
Hudson is offline
post #5 of 18 Old 05-29-2013, 11:14 AM Thread Starter
kgovan32
it was loose but i tightened it and it's still happening, i was doing some research and some said low diff. fluid so ima try that and ill let you guys know. cause i guarantee if it happens to me it's gonna happen to other people hah
kgovan32 is offline
post #6 of 18 Old 05-29-2013, 04:25 PM
jcooklock
1990 XJ Cherokee
I bet that if it was loose that it gonna be wallowed out, especially if you drove with it loose. Did you check that along with tightening it?
by JDNightFox - The terminal velocity of the square headlights is directionally preportional to the force of gravity decelerating the front wheels while the alternator is spinning at 3000 rpm's, minus the friction of the bumper pushing against the airflow with the 13 volt current the steering column is using during the time the vacuum motor is disengaged, but the mirrors must be directionally angled from the driver's window because the hood latches deflect the light refractioning down through the Nitrogen coat on the hood.
jcooklock is offline
post #7 of 18 Old 05-29-2013, 04:39 PM Thread Starter
kgovan32
ya i only drove about 7-8 miles with it loose and it was still sharp
kgovan32 is offline
post #8 of 18 Old 05-30-2013, 08:44 PM
holysirsalad
Can you replicate it by turning the wheel by hand with the front end on jack stands? I had a similar noise from the front passenger side, took off my caliper and found one of the bolts had sheared off in the steering knuckle.
holysirsalad is offline
post #9 of 18 Old 05-31-2013, 03:36 AM Thread Starter
kgovan32
ive tried that, there has to be weight on it
kgovan32 is offline
post #10 of 18 Old 05-31-2013, 04:32 AM
billybooster2
1983 CJ8
Wheel bearings?
billybooster2 is offline
post #11 of 18 Old 05-31-2013, 09:13 AM
Macnasty
Macnasty's Avatar
Check the sway bar end links. If they arent loose, look for surface rust around the head of all the suspension fasteners, thats normally a good indication that theres some movement.
"Today is a good day for a jeep"
Macnasty is offline
post #12 of 18 Old 05-31-2013, 11:08 AM Thread Starter
kgovan32
Originally Posted by billybooster2 View Post
Wheel bearings?
i replaced both wheel hubs
kgovan32 is offline
post #13 of 18 Old 05-31-2013, 11:09 AM Thread Starter
kgovan32
i'ma go check em right now and let you know. it sounds like its coming from down low but you never know
kgovan32 is offline
post #14 of 18 Old 05-31-2013, 12:38 PM Thread Starter
kgovan32
sway bar is tight and no rust, im honestly at a loss with this and i like to believe im atleast a decent mechanic... ha...
kgovan32 is offline
post #15 of 18 Old 05-31-2013, 02:40 PM
Macnasty
Macnasty's Avatar
Check the front and rear brakes. I know, you said its coming from the front, but noises can transfer pretty easily and make it sound like its coming from the opposite end. If the brakes dont apply near the top of the brake pedal stroke you may have rear brake issues because the rear adjustment sets the pedal height. If that checks out, my next guess would be the upper control arm bushings. I re-read your post: Make sure the jam nuts on the lower control arms are tight as well
Macnasty is offline
brake , cherokee , pop , shock , xj
