Loud Noise on accel and decel - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Loud Noise on accel and decel
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 02-14-2011, 06:06 PM   #1
Whoohkid
OK so first post here hope im in the right spot. Anyways i have a 96 jeep cherokee sport and within the last 2 weeks i have had a lour very noticable noise comming from the rear of my jeep. It happens when I hit about 10mph and then its non stop, backing up even. I thought it might be my weel bearings but want to get more info before i start cranking nuts and bolts and bust knuckles
If you need anymore info let me know.
Whoohkid is offline   Reply With Quote Quick reply to this message
Unread 02-14-2011, 06:10 PM   #2
xjfever
xjfever's Avatar
1995 XJ Cherokee
Could be the pinion bearings, u-joints, wheel bearings it's hard to say without some more diagnosing.
xjfever is offline   Reply With Quote Quick reply to this message
Unread 02-14-2011, 06:14 PM   #3
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
If you don't feel comfortable, have a mechanic do this.
First get under there and see if you can shake the driveshaft. If it has a bunch of play, there is a bad ujoint(s). See if you can wiggle the pinion with the driveshaft disco'd, that will tell you if the bearing is in bad shape.
Then, I would pop the diff cover off. Look for metal shavings and such in the fluid that will come out. Check the ring gear, spiders, pinion, etc. for wear / pieces missing.
2000 Jeep XJ - Chopped / Locked
1997 Jeep XJ - Daily Driver
2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust
Join the XJ Owners Club | Download the iMarn® iPhone App!
SIRA 4x4 Offroad Association
Rule #1 - No talking about the weather!
Homepage | Jeepspace Group|Twitter!|Facebook
BeachinXJ is offline   Reply With Quote Quick reply to this message
Unread 02-14-2011, 06:24 PM   #4
Whoohkid
Alright I'll try to do most of the steps you mentioned tomr gotta see what time i get off work, pretty sure my driveshaft isn't turning but not sure i checked quite well, I'll have another post for ya tomr. But thanks for the advice and hopefully this thing will be fixed in no time at all.
Unread 02-14-2011, 07:11 PM   #5
xjfever
xjfever's Avatar
1995 XJ Cherokee
If your drivehsaft isn't turning while your jeep is rolling you have some serious issues, unless someone has installed locking hubs on your jeep.
