Loud Grinding/Rubbing noise when wheel turned all the way to the left or the right - JeepForum.com
post #1 of 5 Old 10-12-2009, 11:16 PM Thread Starter
ScrnE011
When I turn my wheel all the way to the left or the right (such as when pulling in or out of a parking spot) I hear a loud grinding/rubbing noise. It's a very low pitched sound and the car doesn't have to be moving for the sound to happen. It almost sounds as if something is stretching.
When I go over speed bumps, I hear somewhat of a oonce sound (I don't know else to describe it). I thought that the problem might be the drive shaft. I can hold the drive shaft and turn it slightly left and right. Is this the problem? Should I replace the drive shaft and/or the U joints?
ScrnE011 is offline
post #2 of 5 Old 10-12-2009, 11:19 PM
Beefcake7777
mine does the same thing if i turn all the way when idling...... id definitely like an answer for this.
Beefcake7777 is offline
post #3 of 5 Old 10-13-2009, 01:30 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
You should correctly determine the source of the noise before you replace random parts in the hope that you fix something.
If you cannot diagnose the noise yourself, find the local 4x4 shop or an independent auto repair shop. Dealerships and brand name, chain store repair shops are only interested in selling you expensive new parts and charging you many hours of labor to install them. An independent repair shop or 4x4 shop may find that something was loose or only needed a small repair or slight adjustment instead of a complete replacement with expensive new parts.
CJ7-Tim is offline
post #4 of 5 Old 10-13-2009, 04:06 PM
Beefcake7777
doesnt really answer the op's question..does anyone else know what it might be?
post #5 of 5 Old 10-13-2009, 05:29 PM
Jenner
did you try poping the hood and having someone turn the wheel so you can see/hear where the noise is coming from specificly? it would be easier for people in the forum if it were narrowed down slightly.
I think thats why CJ-Tim said to take to a 4x4 shop if you can't determine that. You don't have to have them repair it but they can point you in the right direction.
1998 Jeep Wrangler SE
Project.
Mods so far...none
Maintenance to keep it on the road...Oh my god.
Jenner is offline
Weird rubbing/grinding noise Finallyajeep XJ Cherokee Technical Forum 6 04-13-2009 10:55 PM
Grinding/maybe rubbing noise gwayms XJ Cherokee Technical Forum 3 04-03-2008 03:25 PM
grinding rubbing noise dsarraf XJ Cherokee Technical Forum 5 06-26-2007 10:22 AM
grinding/clunking/rubbing from left rear iwishihad1 XJ Cherokee Technical Forum 5 04-07-2007 07:44 AM
loud grinding noise johnyanmar XJ Cherokee Technical Forum 5 04-06-2002 08:48 AM
