Quantcast The loud clunk I hear when Four Wheeling with stock suspension.... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > The loud clunk I hear when Four Wheeling with stock suspension....
Official Chassis Saver Rust Preventive Truck & Auto UnTJ 5.25" Speaker Adapters - NalinMFGSALE -- Yukon Gear Free Spin Hub Conversion Kit - Dana 30
Old 11-12-2008, 04:32 PM   #1
locohosa
Is that the suspension bottoming out, or something else broken? I only noticed it when I was hitting bumps at a *Kinda* fast pace, when I slowed down it didnt happen at all. I assumed it was the suspension running out of travel, but I wanted to double check with some other Jeep owners.
If it is the suspension, then which component is running out of travel? If the springs are running out of travel before the shocks, then a 2 inch lift would help me some while I am waiting to save up for new struts. If its the struts bottoming out, then I know there is no point in doing a two inch now, and I should wait till I have a bit more money.
Any way, let me know please
locohosa is offline   Reply With Quote
Old 11-12-2008, 04:34 PM   #2
ClassicVA
mine has been doing the same thing, along with dips in parking lot exits and other random bumps. im pretty sure my trackbar bushing is wearing out. or already worn out
~1998 Cherokee Classic - 3.5" RE Superflex, 32's
~XJ Owners Club Member #134
ClassicVA is offline   Reply With Quote
Old 11-12-2008, 04:38 PM   #3
BIG_J
2005 KJ Liberty
Heck, i cant even remeber which noise mine make where. it make too many of them. Doesn't help that i cant drive it right now either.
BIG_J is offline   Reply With Quote
Old 11-12-2008, 04:38 PM   #4
Magus2727
Magus2727's Avatar
1995 XJ Cherokee
you don't have struts, just springs and shocks. stock shocks would be hard to bottom out, you would have to be jumping the thing to bottom them out. My guess is there is something in your steering that is loose. Ball joints? Track bar? Tie Rod?
NAXJA Member #2619
1995 Jeep Sport Cherokee 4x4 with an Auto and 4.0L
B&M Transmission Cooler and Autometer Tranny Temp Gauge, Ruff Stuff Diff Cover on D30.
Taraflex 1.5" BB (rear shackle only), HD Quadratec leaf springs, RE 3.5" front springs, OME Long shocks, JKS Adjustable Track Bar from K.O.R.
Daystar Control Arm Bushings, Bushwhacker Flairs, Rhino lining along bottom trim, AGR PS pump with Cooler & Filter.
Bored TB, APN Manifold, New Downpipe, Magnaflow High Flow Cat, Flowmaster Super 44.
Dual Oil Relocation Kit running two K&N301 size filters, Autometer Digital Cobalt Oil Temp and Oil Pressure Gauge.
Magus2727 is offline   Reply With Quote
Old 11-12-2008, 05:05 PM   #5
locohosa
Struts, sorry, that's my jeep noobness showing again. My clunk was basically driving too fast over rough terrain, seemed to be coming from the back, and had no connection to my steering. As the axle comes up, could it be hitting something on its way up? I wasnt jumping anything, but I was pushing her a little bit.
I dont know enough about suspension to even guess, and my grandfather, who is a tranny guy, said it sounded like a bad tranny mount. I honestly just assumed it was the suspension running out of travel.
Old 11-12-2008, 05:11 PM   #6
lyleorszulak807
1988 XJ Cherokee
It could be your rear sway bar hitting against the body....look for good size dents right above the rear tire in the center looking sideways. At least that's where it hits for me.
88 Jeep Cherokee 4.0L - RE 5.5" springs | Teraflex shackels in the rear | RE1660 HD track bar with drop bracket | Rock Krawler adj UCA/LCA
ROLLED & TOTALED! 89 XJ 4.0L Renix AW4 | Rustys Air intake kit Steering Box reinforcement bar Bomb proof Motor Mounts | RE HD Track Bar, drop down Bracket, support brace | Cobra 75sxt CB | 33x12.5x15 MTR's on Crager soft 8 | Teraflex and 5.5" RE HD springs | yada yada...[/CENTER]
lyleorszulak807 is offline   Reply With Quote
Old 11-12-2008, 05:15 PM   #7
locohosa
Thank you, I will do that as soon as it stops flooding outside.
Is this why I have heard of people removing their sway bars?
Old 11-12-2008, 05:23 PM   #8
lyleorszulak807
1988 XJ Cherokee
that and more flex, really doesnt do much IMO in the rear. If you drive like you stole it keep the front one on. Personally I run no sway bar front and rear....but most of the people on this forum will tell you how dangerous it is..blah blah.
Old 11-12-2008, 05:28 PM   #9
locohosa
I dont ever drive it like I stole it till I get in the mud, if I did I would spend all my money fixing it, and never lifting it. I think I will leave them right where they are for a little while, and once I get a 2 inch lift, that will stop, right?
EDIT: That is, assuming its the sway bar hitting
Old 11-12-2008, 05:32 PM   #10
lyleorszulak807
1988 XJ Cherokee
well if you have stock suspension, not sure if its the sway bar or not....your bump stop should hit the axle before the swaybar hits the body. Never had a stock height XJ so I wouldn't know....but if you said its in the rear, then jack up the rear by the diff and see whats hitting when compressed. welcome to the wonderful world of heeps.
Old 11-12-2008, 05:34 PM   #11
locohosa
Would the bump stop make a noise half way between a Bang and a loud clunk? ?
Old 11-12-2008, 05:54 PM   #12
kevbow007
could be a bushing??
kevbow007 is offline   Reply With Quote
Old 11-12-2008, 06:01 PM   #13
Magus2727
Magus2727's Avatar
1995 XJ Cherokee
If you had to guess about how many inches would you say the rear dropped (compressed)? do you know or would you say that the rear end of your jeep is sagging (sitting lower then the front by more then 1/2 and inch?)?
NAXJA Member #2619
Old 11-12-2008, 06:08 PM   #14
chris87xj
Jeepaholic
chris87xj's Avatar
1987 XJ Cherokee
probably not since it's rubber. i wouldn't think you'd even hear it unless it hit REALLY hard.
***Chris***
JeepForum.com/IndyORV@Redbird-SRA
2009 COTY
Originally Posted by wgirvine View Post
You want my opinion? Ok… Shut the hell up... That’s my opinion.
chris87xj is offline   Reply With Quote
Old 11-12-2008, 06:09 PM   #15
locohosa
For all your questions, I dont really know. Now more details.
I have no idea how far the rear compressed, but it was enough that I think its REASONABLE to think I was running out of suspension. Everyone inside the jeep was getting thrown around quite nicely. This only occurred when driving more quickly through the really rough stuff, once I slowed down, then It no longer happened.
As far as sagging, I dont know. This is my first Jeep, and I have only had it a few weeks. I know it feels VERY stiff (Based on driving down pot hole covered roads and speed bumps, not offroading), and the jeep doesn't have the classic worn out feeling when I drive over a speed bump.
Glock Forum
