loose transfer case bolt cant tighten/or loosen - Page 2 - JeepForum.com
post #16 of 20 Old 02-14-2011, 07:40 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
thats what my motor mounts looked like when i did mine, both of them. and so did my tranny mount for that matter. so i have to believe my whole drivetrain was more or less just flopping around to a certain extent.
1990JEEPXJ is offline
post #17 of 20 Old 02-14-2011, 07:51 PM
Diamond-x
1991 XJ Cherokee
Mine too. I replaced with Urethane, now the cab rumbles at idle.
Diamond-x is offline
post #18 of 20 Old 03-12-2011, 01:29 PM Thread Starter
DoctorTim
i have to revive this thread, that bolt on the first post, how do i loosen it? cant seem to find the nut.
96 XJ, geared, 8.8, 5", 33s, dash
DoctorTim is offline
post #19 of 20 Old 03-12-2011, 05:45 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
there is no nut for it.
post #20 of 20 Old 03-12-2011, 06:43 PM Thread Starter
DoctorTim
thanks for trying to give me good advice. but there is a nut, and heres the prof.
I had to get an angle grinder and cut off the head, then i realized i could push it through from underneath and then i had to fish around for it. i didnt realize before i started grinding away that i could get an angled wrench and be done with it.
transfer case lever loose or broke? mell860930 XJ Cherokee Technical Forum 1 02-17-2010 05:19 AM
transfer case lever loose or broke? mell860930 XJ Cherokee Technical Forum 0 02-16-2010 07:34 PM
tryed to tighten loose tilt wheel and.. jersey_jim XJ Cherokee Technical Forum 2 10-17-2007 06:21 PM
how to tighten a loose tilt wheel? jersey_jim XJ Cherokee Technical Forum 8 10-17-2007 09:10 AM
Loosen/Tighten Serp belt balloo93 XJ Cherokee Technical Forum 9 09-05-2006 02:28 PM
