loose transfer case bolt cant tighten/or loosen - JeepForum.com
post #1 of 20 Old 02-13-2011, 02:34 PM Thread Starter
DoctorTim
so i was lookin under my XJ to diagnose some clunking noises that goes on when i change my velocity. I found this bolt that wouldn't loosen or tighten. it seems like there is a locked nut on the other side but i dont know how to get to it. any help?
its the bolt that is directly in the middle of the pic. sry for not circling it, Mac OSX never thought of including a paint application fsr.
96 XJ, geared, 8.8, 5", 33s, dash
DoctorTim is offline
post #2 of 20 Old 02-14-2011, 10:54 AM Thread Starter
DoctorTim
bump
post #3 of 20 Old 02-14-2011, 12:55 PM
egodfrey
egodfrey's Avatar
Any pics from further away or a different angle, cant quite make out the spatial reference
So many people to thank here's a start to the list
Spidertrax, Yukon, rustys, warn, branik, PSC, advance adapters, Bad wheels, interco, essentially off-road. And many more
Most of all thanks too Ian Johnson and the xtreme off-road crew for all their work, and 4 wheel to heal for their part in it too.
egodfrey is offline
post #4 of 20 Old 02-14-2011, 12:59 PM
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
What are we looking at?
And why do you have so much oil leaking?
- Chopped / Locked
- Daily Driver
2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust
Rule #1 - No talking about the weather!
BeachinXJ is offline
post #5 of 20 Old 02-14-2011, 01:11 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
that bolt holds the transmission mount on. if the threads are totally stripped, it can be causing your drivetrain to move and clunk. youll need to remove the cross member to be able to replace that mount and repair the threads.
1990JEEPXJ is offline
post #6 of 20 Old 02-14-2011, 01:15 PM
egodfrey
egodfrey's Avatar
Yea and check your seals and lines while your at it, some serious leaking going on, or you took these pics after driving through a murky lake
egodfrey is offline
post #7 of 20 Old 02-14-2011, 01:16 PM
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
Is that the crossmember in the pic?
- Chopped / Locked
- Daily Driver
post #8 of 20 Old 02-14-2011, 01:19 PM
Ben
There's that, and one opposite that hold the crossmember to the trans.
There's 4 bolts that hold the crossmember to the body.
Support the trans/transfer case, remove the crossmember, drill that broken bolt out & get a new rubber mount right there. It looks like you got nothing left of your trans mount, and that probably has a lot to do with the clunking. That would be on my replace ASAP list.
Ben is offline
post #9 of 20 Old 02-14-2011, 02:43 PM Thread Starter
DoctorTim
This pic was taken directly underneath the transfer case, and the camera was pointed toward the passenger side rear end of the jeep.
I doubt there is a major leak in that area, all the oil spots in my garage are directly under the engine and tranny oil pans.
post #10 of 20 Old 02-14-2011, 02:48 PM
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
Most likely the rear main or valve cover gasket. You have a major leak somewhere close by. It tends to move backwards as you drive (wind / motion).
You need to take the whole crossmember down to fix that bolt. I would grab a friend and get to it.
- Chopped / Locked
- Daily Driver
post #11 of 20 Old 02-14-2011, 02:55 PM Thread Starter
DoctorTim
thanks for help,
so that "transmission mount" holds up the TC? are there any more tranny mounts i need to check out?
post #12 of 20 Old 02-14-2011, 03:07 PM
Ben
There's 3 main mounts that hook engine/trans/t-case to the body.
A motor mount on each side, and that cross member mount.
With that one so far gone, you may want to look at your motor mounts.
Play in one tends to kill the others.
If your motor mounts are broken, you may need a new exhaust manifold.
The motor's movement can break the header at the collectors.
Some guys may tell you to use polyurethane, but I'm a fan of OEM rubber.
That really comes down to personal preference.
Ben is offline
post #13 of 20 Old 02-14-2011, 03:31 PM Thread Starter
DoctorTim
funny that you say that because i just replaced my motor mounts two days ago with OEM rubber mounts. and yes, i do have a crack in the exhaust manifold where it forks. i took a pic of how bad my motor mounts were, lol...
post #14 of 20 Old 02-14-2011, 04:28 PM
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
Yeah, you most likely need a new tranny mount. So, I would plan on replacing that as well along with the manifold.
- Chopped / Locked
- Daily Driver
post #15 of 20 Old 02-14-2011, 05:10 PM
egodfrey
egodfrey's Avatar
Those motor mounts were ****ed,
Mine are bad too, thankfully i have some brown dog mm on the way
egodfrey is offline
transfer case lever loose or broke? mell860930 XJ Cherokee Technical Forum 1 02-17-2010 05:19 AM
transfer case lever loose or broke? mell860930 XJ Cherokee Technical Forum 0 02-16-2010 07:34 PM
tryed to tighten loose tilt wheel and.. jersey_jim XJ Cherokee Technical Forum 2 10-17-2007 06:21 PM
how to tighten a loose tilt wheel? jersey_jim XJ Cherokee Technical Forum 8 10-17-2007 09:10 AM
Loosen/Tighten Serp belt balloo93 XJ Cherokee Technical Forum 9 09-05-2006 02:28 PM
