Loose Steering and Sliding - JeepForum.com
post #1 of 6 Old 03-01-2013, 01:28 PM Thread Starter
ngrubich
My 2000 XJ (3" lift, 31" BFGs; had for several years) has recently started to have a loose steering wheel problem and it feels like I'm almost sliding when going around turns.
I'm getting ready to change out the upper control arms, track bar bushing, and sway bar bushings this weekend as an overhaul project. Is there something else I should look for?
ngrubich is offline
post #2 of 6 Old 03-01-2013, 02:12 PM
Diamond-x
1991 XJ Cherokee
Sounds like it's in 4WD. Check your T/C linkage.
Diamond-x is offline
post #3 of 6 Old 03-01-2013, 03:04 PM Thread Starter
ngrubich
I can hear it shifting into 4H and then over into 4L, so I don't think that is the issue (although the linkage bushings are getting kinda old). My t case 4WD switch isn't working, so I'll go grab one from the store so I can figure out if I'm sticking in 4WD and report back.
ngrubich is offline
post #4 of 6 Old 03-01-2013, 05:06 PM
Diamond-x
1991 XJ Cherokee
If I'm in 4WD and I try a tight turn at low speeds my XJ slides more than it turns.
post #5 of 6 Old 03-01-2013, 06:29 PM Thread Starter
ngrubich
I usually get the sliding at higher speeds, like 10-15mph upwards (like turning onto the on-ramp of a highway). At low speeds (in 4WD), my steering wheel jerks back and forth, but I don't really get any sliding, but then again I haven't really tried to notice it.
ngrubich is offline
post #6 of 6 Old 03-01-2013, 08:50 PM Thread Starter
ngrubich
Update: just replaced the switch on the transfer case and my dash isn't showing that I'm in 4WD; still having the same problem as before (I know the bulb isn't out because the new switch turns the light on on the dash when I move the lever myself).
ngrubich is offline
