Quantcast Looks AWESOME. Try this. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Looks AWESOME. Try this.
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!TJ WW2WW rockers on sale with free gaskets this month.
Old 11-10-2006, 09:50 AM   #1
4.0H.O.XJ
Well, i dont have pics yet. But Im working on it.
Some dick who owned the jeep before me was a sticker nut. Stickers ALL OVER the back hatxch, and it looked awful. (You know the stickers: Uncle bobs 4wd shop, NRA, KBUL 107.5 FM country, a rebel flag, ("Proud ta be a rednick") Buy union, buy american, a Klan rally sticker, and a swastika. ..............all stuck DIRECTLY to the paint instead of the window or bumper)
I got a heat gun and removed all the stickers. .......Then I got a little crazy. I removed the "JEEP" emblems. Then I heated up and removed the "4.0 LITRE" emblems..........Then....the pinstripe came off.
When you peel the emblems off, do it with a paint scraper, pry AWAY from the paint. Next, once all of the stickers are off, SCRUB the whole area down with laquer thinner and a washcloth to remove all the goo.
Now that the back hatch is clean, I wet sanded it with 800, 1200, 1500 and 2500 grit wet/dry sandpaper.
THEN, to MAKE IT SHINE LIKE GLASS........I used a high speed buffer and a foam polishing pad, and used 3M's medium fine cut rubbing copmpound, followed by 3M polishing compound ("swirl mark remover")..It looked awesome.........
....But then I used 3M "Finesse it". That stuff is AWESOME. (Expensive, tho')Its a microfine polishing compound that closes up all microscopic scratches and marks by knocking them smooth and polishing it. UN FREAKIN BELIEVABLE how it shines. Better than my buddies brand new car, BY FAR.
It looks super stealth, its a black XJ, so removing the emblems really cleaned up the back area. Pretty awesome, thought Id share.
4.0H.O.XJ is offline   Reply With Quote
Old 11-10-2006, 10:06 AM   #2
lrsmithwhaley
1991 XJ Cherokee
Sounds cool but
Green with Silver trim 1991 Jeep Cherokee Laredo (DD and Off-roader)
March 2007 Stock Class XJ of the Month
Original Rust Jeep Club Member #2
Green Jeep Club Member #183
Air Force Jeep Club #76
lrsmithwhaley is offline   Reply With Quote
Old 11-10-2006, 10:08 AM   #3
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Sweet. Sounds like a lot of work though. Think it would work on my pig?
"'Did you ever wonder why we had to run for shelter when the promise of a brave new world unfurled beneath a clear blue sky? "
Roger Waters
Matt Gertsch is offline   Reply With Quote
Old 11-10-2006, 10:13 AM   #4
BrunoS
bring that serious elbow grease to my forest green 96! that will save me a paintjob, since my hood and top look like the pig's!
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline   Reply With Quote
Old 11-10-2006, 10:17 AM   #5
ddoffroad
I want to get my pinstripes off desperately!!! Where do you get a heat gun?
99 XJ - 4.0L HO, Rusty's K&N Intake, Rusty's 4.5" full suspension, 31x11.50 Swamper LTB's, 15x8 blk Daytona's, clear lenses, Warrior bumper w/ hooks
Down & Dirty Offroad: http://ddoffroad.com/
My XJ site: http://www.cardomain.com/ride/2488225/
My Old XJ Site: http://www.cardomain.com/ride/2058746
ddoffroad is offline   Reply With Quote
Old 11-10-2006, 10:32 AM   #6
TehHelmet
2008 KK Liberty
Don't put laquer thinner on your paint. Otherwise your paint will look like mgertsch's in no time.
You can use a clay bar for that or rubbing compound, they both work wonders. Trust me, I used to run a detail shop as well as removing & laying pinstripes, graphics, and emblems.
Also, rather than scraping to get behind emblems and pull them off, use a heat gun or blow dryer to heat it up, then take a piece of fishing line and work it back and forth between the body and them emblem. That alone will remove most of the goo.
EDIT: Also, to remove pinstripes painlessly... There is an air tool that can be bought at some place like Harbor Freight, it's fairly inexpensive, and it basically "shaves" it right off the paint w/o damaging the finish. It's a HELLUVA lot faster than the heat gun/scraping meathod.
Colorado Jeep Club Member #76
TehHelmet is offline   Reply With Quote
Old 11-10-2006, 10:32 AM   #7
Whobeme
Harbor Freight has heat guns for under $20. If you are only going to use it once in awhile or for light to medium duty jobs it'll do just fine.
Whobeme is offline   Reply With Quote
Old 11-10-2006, 11:23 AM   #8
4.0H.O.XJ
Yeah, I forgot to mention the whole washing of the paint real well after the laquer thinner wipedown.
Only use the laquer thiner on the seriously ytough goo spots, and wipe it down real good with soapy water afterwards, or it will soiften and crack the paint. It DOES work well, however.
Pinstripe removal:
Heat gun or hair dryer, warm, sunny day. Pinch the edge with your thumbnail, and peel whatever portion you can back. Keeping it warm, attempt to peel it off. If this does not workkkkkkkkkkk..........
Get thin piece of flexible plastic under there. I used a sliver of a body filler knife and my thumbnail. Peeeled as much off as I could, then hit it with the laquer thinner to get the remains off.
Cool tip on the fishing line trick Thanks
Old 11-10-2006, 11:30 AM   #9
trizog
Napa sells a product they call a vynyl erasure it costs 14.99 and will eat right through stickers without damaging paint it is what detail shops use. its good that you got good results from your process but imo its was a combination of luck and being careful but overall laquer thinner and razor blades are bad for paint.
trizog is offline   Reply With Quote
Old 11-10-2006, 04:07 PM   #10
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
That'll buff right out!
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 11-10-2006, 05:12 PM   #11
Ivanito
I did that and it gives the jeep a cleaner look. I used a heat gun/professional goo gone and it came off fairly easy.
Ivanito is offline   Reply With Quote
Old 11-10-2006, 05:40 PM   #12
DirtyCommanche
Actually, it will.
But, it's a trickey process. The clear delaminates from the base paint, but doesn't do it uniformly. It will however come OFF with enough buffing/wet sanding/scotchbrite, you just have to be careful not to go too deep and wreck the base. Then you can clear coat it again and it'll look about 100000X better than that.
Or say f' it and paint it flat black or olive drab.
DirtyCommanche is offline   Reply With Quote
Old 11-11-2006, 02:29 AM   #13
Staffybull603
so you detailed your car ??? I've debadged every car i've had since 16...always thought it looked better. why'd u skip the clay bar ?
Staffybull603 is offline   Reply With Quote
Old 11-11-2006, 12:16 PM   #14
JohnnyX
yeah my and my friends always debadge everything. just use a blowdryer for hair it works fine. use WD40 afterwards to get all the glue and stuff off. make sure you wipe it clean and wash the WD40 off good afterwards. check otu the first link in my signature, its my jeep completely debadged
North Jersey Jeep Club Member- #83
www.northjerseyjeepclub.org
the rig:
http://img402.imageshack.us/img402/8980/jeep2xq0.jpg
CHECK OUT MY BAND- www.myspace.com/myrtleave
JohnnyX is offline   Reply With Quote
Old 11-11-2006, 07:47 PM   #15
n20jeep
1993 XJ Cherokee
still no pics???
n20jeep is offline   Reply With Quote
Glock Forum
