looking to get the G/F an xj would like to get her one with a d44 rear, need help - JeepForum.com
post #1 of 20 Old 08-09-2006, 08:34 AM Thread Starter
cutlass1972
cutlass1972's Avatar
I am a TJ guy and am looking to get my G/F an xj.
I would like to get her one with at least a d44 in the rear if not one up front too, but I would settle for a d44 in the back and d30 up front. My question is this (and yes I know this info has been posted again and again, but I cannot dig it up with a search) what does a d44 look like? My TJ has d30 in the front and d35 in the rear, so I know what they look like, but what about the d44?
Also, we test drove a 97 grand cherokee lareado and it had a full time and a part time 4wd setting, does that mean that it has a center differential for the full time 4wd like a subaru? Is this any indication of the axle type?
Thanks in advance!
97
2.5L
4.10 gears
5 speed
31x10.5x15
emerald green with a spice top
cutlass1972 is offline
post #2 of 20 Old 08-09-2006, 08:40 AM
cmassey_2006
2006 WK
This thread has alot of info about stock XJ specs: http://www.jeepforum.com/forum/f11/cherokee-stock-specs-26256/
The d44 pumpkin looks like an apple on its side (I'll post the pic when I find it)...
EDIT: OBXJ beat me to it.
cmassey_2006 is offline
post #3 of 20 Old 08-09-2006, 08:44 AM
OBXJ
OBXJ's Avatar
2003 Jeep WJ Limited - Stock DD
1998 Jeep XJ - 4.0L, AX-15, Np231, Chrysler 8.25 rear, Dana 30 front, RE 4.5", 305/70R16 BFG MT's, 16" Cragar Soft 8's, OBA, Bushwacker Flares, AA SYE, CRC Custom DS, RE Gen2 Disco's, OME Nitro's, IPF H4 Headlights, Hella 500 Driving Lights, Factory Overhead Console, Surco/Yakima Roof rack, Hidden Hitch, K&N Apollo Intake, AirFlow Snorkel, AirRAID TBS, Alpine head unit with Sirius Module, sealed & hydroblocked.
OBXJ is offline
post #4 of 20 Old 08-09-2006, 08:47 AM Thread Starter
cutlass1972
cool! thanks for the diff pics!
What about the fulltime / part time 4wd buisness? Does that mean it has a center diff? does it mean that the front and rear diffs have limited slip?
97
2.5L
4.10 gears
5 speed
31x10.5x15
post #5 of 20 Old 08-09-2006, 08:54 AM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
To find a factory D44 you will need to buy a 87 XJ or find a junk yard D44 and bolt it up.
The D44 was never an option on the US and Canadian XJ, just the south american ones.
The TCase you are referring to on the XJ is a NP242. It has the equivilant of a diff in the case, but it's not necessarily one. It will allow for different speeds of the front and rear DS.
What does she want to do with the XJ? Lift? Tires? Terrain?
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #6 of 20 Old 08-09-2006, 08:56 AM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Sorry, didn't see the other question.
The rear diffs were offered with a Trac-lok LSD, the fronts were never offered with a factory LSD.
93 Sport
Specs in Profile.
balloo93 is offline
post #7 of 20 Old 08-09-2006, 09:07 AM Thread Starter
cutlass1972
she will most likely not do any serious off roading (though I might be tempted to play with it a little hehe). She is interesting in being able to get to work in the snow (we have a long steep gravel driveway and live out a rural state route). She also is liking the idea of the full time 4wd since I have explained why you have 2wd, 4wd full time, and 4wd part time. She is from Los Angeles, we live in rural KY, she is a little afraid of driving the back roads in the rain and snow. We would like to be able to pull a small trailor with it so I am looking for one with the 318 instead of th I6, this is also partial reason for wanting the heavier axle which it seems might not be an option on a 97 or newer cherokee.
we will most likely put 31X10.5X15 bf goodrich T/A all terrains on it for her, this is what I run on my TJ and have gotten good even service out of them.
97
2.5L
4.10 gears
5 speed
31x10.5x15
post #8 of 20 Old 08-09-2006, 09:17 AM
cmassey_2006
2006 WK
D44's are hard to come by, but you can check your junkyard periodically, as stated. Until you find one, look for an XJ with the Chrysler 8.25, instead of the Dana 35, as it is a little beefier. How much weight are you trying to tow?
post #9 of 20 Old 08-09-2006, 09:21 AM Thread Starter
cutlass1972
not a bunch, I have a little fiberglass jon boat that we haul (my 4.0L ranger hauls it fine) and we would like to be able to tow a 1500lb +/- trailor on the interstate
97
2.5L
4.10 gears
5 speed
31x10.5x15
post #10 of 20 Old 08-09-2006, 09:24 AM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Alright, I think you are looking for a grand Cherokee and not a XJ. The XJ was never offered with a V8, so I will move it to that section. FYI the ZJ did have an aluminum D44 available.
93 Sport
Specs in Profile.
balloo93 is offline
post #11 of 20 Old 08-09-2006, 09:27 AM Thread Starter
cutlass1972
ah, I appologize, I was not aware that a cherokee and a grand cherokee where different models. well, hello grand cherokee people, anybody here got any suggestions?
97
2.5L
4.10 gears
5 speed
31x10.5x15
post #12 of 20 Old 08-09-2006, 09:27 AM
Rock Kustoms
Rock Kustoms's Avatar
your in the wrong forum bud. this is the cherokee forum, XJ, your looking for a grand cherokee, ZJ. the ZJ is available with a 318 (5.2) V8, the XJ isnt, only 2.5 or 4.0.
Also, all the V8 ZJ's come with a d44 rear. they have an aluminum center section, and while they are better than a d35, for wheeling or increased power, the tubes WILL spin
edit: balloo beat me too it
Rock Kustoms is offline
post #13 of 20 Old 08-09-2006, 09:28 AM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
All 96-up V8 Grand Cherokee's have the D44a.
Also sence you seem alittle confused
XJ=84-01 Cherokee
ZJ=93-98 GRAND Cherokee
WJ=99-04 GRAND Cherokee
2013 FR-S
BlaineWasHere is offline
post #14 of 20 Old 08-09-2006, 09:29 AM
Rock Kustoms
one forum above this one, and you got a whole mess of grand cherokee people
edit: damn it balloo, beat me too it again, by moving it lol
post #15 of 20 Old 08-09-2006, 09:30 AM
BlaineWasHere
BecauseRacecar
The thread is now in the GC section.
2013 FR-S
Height of Rear Liftgate + Rear Bumper and Tire Carrier Question KWAG XJ Cherokee Technical Forum 2 08-19-2012 11:50 AM
Rear brakes doesnt stop rear tires from spinning toates89 XJ Cherokee Technical Forum 6 12-19-2009 02:00 AM
Make rear axle freewheel - Bad Rear Diff - Drive in 4HI LR103 XJ Cherokee Technical Forum 12 11-01-2007 11:57 AM
Rear Tire Carrier with stock rear hidden hitch yellow81cj5 XJ Cherokee Technical Forum 23 06-28-2006 01:46 PM
popping in rear - Rusty's 3" rear leaf spring bushings dakotaguy1999 XJ Cherokee Technical Forum 3 12-13-2003 02:25 AM
