Looking for common Jeep 4.0 problems - JeepForum.com
post #1 of 6 Old 08-20-2009, 11:22 AM Thread Starter
SkierAtHeart
I have a 95 Jeep Cherokee 4.0 and it has 181,000 miles on it. I would like to try and make it last 250,000 miles I usually put about 12,000-13,000 miles in it a year. Most of my driving is in the winter time, but I do tow a trailer with a raft on it in the warm summer months. I might be getting a snowmobile this year so more towing. I don't do much off roading but dirt roads can be common during the summer months.
I am looking for common problems that I can try and take care of prior to them happening. For instance I just broke a motor mount I did a search and it looks like its a fairly common problem with the 4.0's. Some of the things I have replaced are water pump, thermostat, starter, alternator, and value cover gasket. If you guys can can give me some ideas of things I should change now that would be great.
Thanks
SkierAtHeart is offline
post #2 of 6 Old 08-20-2009, 11:31 AM
justanotherjpr
Add transmission cooler, valve cover gasket always leaks at the back of the head. Keep it full of oil and it will last forever.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #3 of 6 Old 08-20-2009, 11:56 AM Thread Starter
SkierAtHeart
Thank you, What about ball joints? A couple of the rubber boots look pretty worn.
post #4 of 6 Old 08-21-2009, 05:38 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Most guys pocketbooks preclude them from changing stuff out before its time. I'd recommend you do the same; it just makes sense on an economic basis. Most of the problems with the XJ won't leave you on the side of the road. Fix it when it becomes symptomatic.
As for sensors, the one that is a very common failure on the 4.0 is the crankshaft position sensor. "Some" guys replace it strictly as a preventive measure and keep the old one as a spare. They are kind of a PITA to replace, especially on the side of the road or on the trail.
Best recommendation for longevity? Replace ALL fluids regularly. Coolant, oil, tranny, differentials. I see guys go nuts all the time with mods, etc and they still have their original tranny fluid in there at 75k. Fluids are the lifeblood of your XJ.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #5 of 6 Old 08-21-2009, 05:47 PM
cornbrizzle
1992 XJ Cherokee
If there's no play in them just keep them greased real good and they should be fine
Brizzle
ďDonít Tread On MeĒ
www.highsprings.com
cornbrizzle is offline
post #6 of 6 Old 08-21-2009, 08:03 PM
loneeagle78
1990 XJ Cherokee
the main leak I have been replacing up here in ND lately has been the trans/transfer case seals. the seal at the back of the trans starts leaking and it comes out between the two. the other is make sure your rear diff is always full. rear axle seals are another problem area.
loneeagle78 is offline
common problems with Jeep A/C system? JEEPINWI XJ Cherokee Technical Forum 23 08-14-2015 08:32 AM
Common problems in used XJs?? 4.0H.O.XJ XJ Cherokee Technical Forum 13 10-29-2006 02:08 PM
Common Jeep Problems Voyager XJ Cherokee Technical Forum 18 08-25-2006 11:31 AM
What are the common problems of an 89 with a 4.0 cmckeon XJ Cherokee Technical Forum 4 09-02-2005 08:31 PM
Common problems in 96 Nightcon777 XJ Cherokee Technical Forum 5 05-01-2005 08:51 AM
