long cranking until start, then quick start
#1 | |
97 Cherokee Sport 4.0. I try to crank my Jeep and it just cranks and won't start until half a minute. At anytime I stop cranking, return key to off, then crank it starts immediately and runs fine. It does not matter how long I crank it. It won't start on the first key turn. Crank for 5 seconds, key off, crank and starts immediately. Crank for 10 seconds, key off, crank and it starts. So now my normal procedure is to insert key, crank for 2 seconds, key off, crank and it fires immediately. After it has been running for any length of time, on the next start it cranks immediately but at some point after sitting off, maybe about 2 hours, a guess, it does the long crank problem. What is going on? Thanks. Joe
#2 | |
I don't know why, but judging from previous posts on slow starting, its seems common. Except cranking for 30 seconds without starting is unusual. But try this for the hell of it. Turn key till ignition is on, wait for the beeps to stop, (about 5 sec) and the turn the key the rest of the way and see if it starts. I have a theory that on many injected XJ's the fuel system has to build up pressure. |
#3 |
My '97 has always started great - just look at the key and it fired up- until a week ago. Took my rig on a 1400 mile trip, pulling a small trailer (about 1500 pounds). Ran fine the whole trip but ever since I got back, I need to crank it anywhere from 5 to 10 seconds before it starts. Quite frankly, I'm worried about the wear and tear on the starter,
Any ideas/suggestions?
'97 Cherokee Sport, 4.0 I6 4x2 Stock |
#4 |
Correct me if im wrong, but it seems as though the XJ's have a problem with "quick" starting. Even though it may not matter, mine takes about 5-10 each time i crank it.. Even when its been running for a while. I think it's just a flawl in the fuel system. But Half a min is way too long to be starting the truck. Did you try the Fuel Pump? That seems to be a big flawl in starting. Other things are plugs/Dizzy/Wires and Injectors.. The pump has to build pressure so the sys will work, thats why if you turn to ACC, before starting and wait a few sec., it helps sometimes. Try a few of those and let us know!
Cheers, :J
- 1989 XJ Laredo 4x4 w/I6- Valiance - -*HAS: Cb Radio , 200w Pioneer amp, Pioneer HU, Pioneer Speakers*- "Jeep, Eating Chevy's, Sh!tting Fords!" -Dam I need me a Jeepin' Girl- http://www.cardomain.com/ride/2059999/1 |
#5 |
Nightwolf is right... try turning the key to acc...wait til you hear the fuel pump cycle and shut off. This builds pressure in the system... then crank it... saves the life of your starter and the fuel pump. But 30 seconds sounds like another issue like plugged fuel filter, bad wires/plugs, coil, or compression problem.
1993 XJ Sport RIP (Parts) - 189k, white, 4.0, automatic, command-trac NP231 1996 XJ Sport Daily Driver - 95k, stone white, 4.0, automatic, selec-trac NP242, Tow Hooks, SRB fog lights, tinted glass. 2005 Wrangler Rubicon Summer Toy - 8k, 100% STOCK...silver, automatic, soft and hard tops and doors My Pics "life moves pretty fast... if you don't stop and look around once and awhile, you could miss it"...F. Bueller |
#6 |
ive been dealing with similar issues for months now. the starting system was designed by a retard I think (no offense to the mentally handicapped).
if you turn the ignition key ON right away, the fuel pressure dumps back into the tank through the return line. thats why theres a long cranking because theres not enough pressure building up. it eventually builds up though and the truck will start do what was posted above. ignition to accessory then wait then start. i have a brand new pump putting out 125psi. i wait for it to cycle off and then start and it goes easily. if I just jump into start then it takes many seconds to start. also, listen for the fuel pump noise when you first turn the key. 2 out of 5 times the pump wont cycle on at all. i dont know if its a computer program doing that or what but I know for a fact that the pump doesnt cycle on for every key turn. so if you dont hear the pump, turn off and try again. i got annoyed with the whole fuel starting system and installed a switch that just puts 12v to the fuel pump on startup. i turn it on, start the truck, then turn it off real fast and let the regular truck controls take over. Never fails.
88 Cherokee Limited 6cyl 4L stock. Fixed by a girl: in tank fuel pump, TPS, CPS, rear hatch, wiper motor, interior lights, front-rear differential oil, A/C, ballast resistor automatic bypass home-made circuit, power steering, rear wiper motor, 4wd slip, 2 power windows not fixed: major belt squeak from crank pulley alignment, rear diff gets hot, cruise control, rear bumper rot |
#7 | |
Last night I changed plugs, wires, cap and rotor. The plugs that came out looked fine but the wires were original and the rotor and cap had normal wear/pitting. I'm at 120,000 mi. so new wires were in order. It started a little easier this morning, but I'll need to give it a few days top see if its back to normal.
#8 |
Get ready to change the pump. It happen to my 98, long cranks second attempt quick start up. Did a little research and found there's a check valve thats not holding pressure in the line. so when you try and start your jeep nothings pushing the fuel until you've built up enough psi in you line. What sucks is everything is in the tank the regulator, filter, and of course the pump. I brought the hole assy. just to be sure and it starts like a champ now. Good luck
#9 | |
the way you can check is when you hear the pump prime itself (dont start it) you then pop the hood and check for pressure.
#10 |
It looks like it will be the fuel pump. Thanks everyone. I had a suspicion it would be the pump. Fortunately I know the tank is easy to drop (from experience).
#11 |
If it was the pump I would think it wouldn't run very well at all when it did start. If it's starving for fuel during start up then wouldn't the same hold true while running?
Did you try the CPS? Mine is bad (I assume) because it takes like 5-10 seconds to start. But when it runs it runs perfect. Just a thought.
[B]2000 XJ Classic[/B] Stock for now |
#12 | |
Think Your Jeep Is Fast??? Click Here!!! http://www.jeepforum.com/forum/f180/street-section-competition-prizes-728298/ |
#13 |
I have that probelm with my 92 it takes a while crank i changed the plugs, wire, cap, rotor, I thought it woud fix it cause the plugs were horrible one had build up that covered the gap. but it still cranks slow I am going to try the fuel filter next and maybe so fuel injector cleaner. when you get in your jeep just turn teh key to the on postion and wait if you listen closely you might be able to hear the fuel pump kick on and about 3 secs later it will cut off once the line pressure is built up then try and crank it.
[URL=http://www.cardomain.com/ride/2121164]Two awesome XJs[/URL] 92 Larado, 4x4, 4.0 liter, 140,000 miles, 3 Inch Rocky Road BB, 31 ATs 95 Country, 4x4, 257,000 miles runs like a champ!!, 4.0 liter, Stocker can't convince dad it needs a lift!! |
#14 |
before you go crazy with the pump did you at least check for fuel pressure at the injector rail thing? turn the key to accessory but dont start. the pump should run for 1 second. check under the hood for pressure. if the pump check valve is shot you wont have any pressure on the rail. if you have pressure then the pump might not be the problem.
#15 | |
SPACE FOR RENT
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
