Locking Rear Drum Brake - JeepForum.com
post #1 of 5 Old 06-29-2012, 08:58 AM Thread Starter
rapidcycler
After my normal 26 mile commute, in dry , hot weather, what seemed to be my right rear drum locked and dragged the tired. It literally squealed. I was doing about 25-30 mph and had just trouched the brake. I am in line for a pad change, perhaps rotor as well? Is there some issue that I am missing? I did a search and found a lot of stuff about wet brakes, but mine were dry, and I had already driven over 25 miles.
thanks
rapidcycler is offline
post #2 of 5 Old 06-29-2012, 01:49 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Do the brakes need servicing or not ? If they do, see if that fixes the problem. Pads/rotors or brake shoes/brake drums are replaced with new parts at the same time. You should not re-use old parts with new parts. You should probably should consider bleeding the brakes and removing all the old brake fluid, as you refill with fresh fluid.
CJ7-Tim is offline
post #3 of 5 Old 06-29-2012, 05:49 PM Thread Starter
rapidcycler
Agreed. And I got all of the materials to do just that today with the same thought in mind. If that fixes it great, and if it doesn't it narrows down the diagnosis. However, on the way from autozone(I went at lunch), the delivery people called saying that my lift would arrive on monday between 10 and 6. Since I have to change the brake lines and bleed the brakes anyway, I figured I'd wait until after the lift is installed next week. It has never happened before, and it hasn't happened since.
I got the RE6130 4.5" Super-Flex w/ Rear Leaf Springs Lift. But I'm only going 3.5 inches. Had the springs swapped for 3.5 springs and shims instead of TC drop kit. Got SYE and TW drive shaft. When they said the lift would be here monday, I ordered my tires. Also trying to identify source of oil leak. Will post pic in few minutes on that.
thanks, for the reply.
post #4 of 5 Old 06-30-2012, 08:24 AM
ironman2427
1997 XJ Cherokee
Is it disc or drum brakes? Do you do your own work or have a mechanic? These things can come into play. You could have a bad axle seal in the back causing your brakes to hang up. You could have a piece of broken hardware behind your brake drum, ebrake cable could be stuck, etc.
"When you try to put 300 horsepower in a car designed for 100, you learn what development means," --Carroll Shelby
ironman2427 is offline
post #5 of 5 Old 07-03-2012, 08:38 AM Thread Starter
rapidcycler
You called it Tim, was brake fluid (sometimes us newbs do listen)! I'd forgotten what driving on good brakes feels like.
Thanks!
98 jeep cherokee , brakes , drum , rear , xj
rear right brake drum getting hot smurfette XJ Cherokee Technical Forum 14 07-15-2015 05:28 AM
Rear Brake Drum Leak bjame010 XJ Cherokee Technical Forum 3 07-29-2012 08:02 PM
Rear drum locking up... hmm... MikeyJ XJ Cherokee Technical Forum 5 02-02-2009 09:33 PM
Rear brake drum stuck on chadfrom610 XJ Cherokee Technical Forum 4 03-10-2008 12:22 PM
Drum brake locking up. 1996xj XJ Cherokee Technical Forum 6 01-08-2008 07:28 PM
