Lock Right Locker won't engage!?!? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Lock Right Locker won't engage!?!?
Unread 10-14-2009, 09:30 AM   #1
harleyhector
1989 XJ Cherokee
I just installed a "Lunch box" type Lock Right locker in my C8.25. I have done 3 before and had no issues. I installed the locker per the Owners/install manual that it came with. I use 85/140w oil to quiet down the ratcheting sound that they make. After the install was completed, I put my Jeep in drive. It wouldn't move. It makes a slight grinding noise as if you are in a standard shift vehicle and missed a gear, just not as loud. As I press on the gas, I hear the gear and locker assembly spinning however the locker is not engaging and will not propel the Jeep forward or rearward for that matter. I took it completely apart and checked every part and piece for damage. There was none. So again I re-installed it and got the same results. Any help or advice would be greatly appreciated. Thanks in advance.
harleyhector is offline   Reply With Quote Quick reply to this message
Unread 10-14-2009, 09:33 AM   #2
NotURMailman
NotURMailman's Avatar
Could they have sold you the wrong locker? It sounds like the side gears aren't engaging the shaft splines...
My RHD TJ - Savvy equipped... And loving it! - Durty Rok Carolina Offroad
I drive on the right side, what's wrong with you?
Be very careful with the wife mod. Uninstallation can be extremely expensive. Wife mods have been known to take the Jeep and all other mods during the uninstall process. Also, make sure you service your wife mod properly as often as humanly possible. Wife mods not properly serviced may malfunction or uninstall themselves at any time.
NotURMailman is online now   Reply With Quote Quick reply to this message
Unread 10-14-2009, 09:41 AM   #3
harleyhector
1989 XJ Cherokee
I suppose it could be possible but, i check the part numbers and they match to the Lock Right website list. I bought it at a local 4x4 shop. I asked them, and they say it looks right. I brought them the carrier and all other parts and the assembled it on a bench to make sure it was correct. I then brought it home and re-installed everything. It just spins. Very frustrating. Thanks for the thoughts. I really do appreciate it. I ask Lock right tech line and they were all but useless. I call my local Jeep dealer and got the same results.
Unread 10-14-2009, 09:43 AM   #4
NotURMailman
I would pull the side gears and axle shafts and check the spline engagement with the parts out. I'm unfamiliar with the 8.25. Is it a C-clip axle?
Unread 10-14-2009, 09:48 AM   #5
harleyhector
1989 XJ Cherokee
Yes sir. it is a "c" clip axle. The shafts do fit nicely through the side gears. Nice and tight and the clips go right into place.
Unread 10-14-2009, 10:08 AM   #6
harleyhector
1989 XJ Cherokee
I just read about a guy with a similar problem. He mentioned that he used bearing grease instead of axle grease on his locker components. could that really be the issue? I may have used bearing grease as well. I am not at my garage but, I think that is infact what I used. Bearing grease.
Unread 10-14-2009, 10:11 AM   #7
justanotherjpr
Doubtful - it should engage no matter what. Have you done the 'lock test' with the cover off to watch the locker? Can you snap a picture of it in the carrier for us?
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline   Reply With Quote Quick reply to this message
