location of low-pressure port - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > location of low-pressure port
Father's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPIRough Country Lift Kits and Parts!
Unread 04-13-2008, 08:42 AM   #1
toxworth
can someone tell me ( or better yet show me) where the low-pressure a/c port is located on a 1999 jeep cherokee?
Dan
toxworth is offline   Reply With Quote
Unread 04-13-2008, 08:46 AM   #2
AznDrgn
Follow the fat line off the back of the compressor until you reach a port and that'll be your low pressure port most of the times it'll have a blue cap on it and the high side will have a red cap on it. No worries if you try the wrong one, the low pressure port has a different fitting on it than the high pressure port so all the self recharge kits only fit the low side.
'87 Jeep Cherokee Laredo 4.0L, NP231, AW4, 5.5" lift, s10/waggy/XJ bastard pack, 7" fabtech TJ coil springs - Weekend play thing
'83 Porsche 944 2.5L Callaway turbo - Daily driver
'81 Porsche 924 - Custom EFI and forced induction project
'83 Porsche 944 2.5L - Sold
'78 Porsche 924NA 2.0L - RIP
AznDrgn is offline   Reply With Quote
Unread 04-13-2008, 11:03 AM   #3
AZ Jeff
The ports on an R134a system are designed so that only the correct fitting will connect to each one (they are different sizes). Thus, you can ONLY connect a fill fitting to the low side.
BE CAREFUL when adding more refrigerant. Unless you are experienced working on AC systems, it's possible to OVERFILL the system and DAMAGE the compressor. (Just a friendly warning---every year, some guy on one of the Jeep forums manages to do this because he/she doesn't understand the intricacies of the AC system. Don't become one of those guys.)
AZ-Jeff
1992 XJ 2" lift -- RIP
2000 XJ 3" lift -- Australian Ford Big Brakes up front, rock rails, ZJ rear discs (with WORKING parking brake), C4x4 rear bumper/tire carrier, Hella H4 headlights, IPF driving lights, OEM skid plates, OME springs/shocks, JKS LCA's, JKS Sway Bar links.
AZ Jeff is offline   Reply With Quote
