link to homebrew sway bar link.......? - JeepForum.com
post #1 of 5 Old 06-19-2007, 10:37 AM Thread Starter
expressfish
1990 XJ Cherokee
cant find it in the search forums........can ya help a brother ouT ??
expressfish is offline
post #2 of 5 Old 06-19-2007, 10:48 AM
LEAD_NOT_FOLLOW
LEAD_NOT_FOLLOW's Avatar
1989 XJ Cherokee
LEAD_NOT_FOLLOW is offline
post #3 of 5 Old 06-19-2007, 11:02 AM Thread Starter
expressfish
1990 XJ Cherokee
thanks, isnt there one about fabbing up longer links ? I thought I could probably use a piece of 3/8 all thread, weld a washer in place for upper and rig the bottom end ?
post #4 of 5 Old 06-19-2007, 12:32 PM
RussoGuitar
1989 XJ Cherokee
I extended a set of stock links for someone, i just cut the loop off thew bottom, and welded in a peice of rod that was few inches longer.
RussoGuitar is offline
post #5 of 5 Old 06-19-2007, 02:41 PM
jfiscus
jfiscus's Avatar
1993 XJ Cherokee
IIRC, if you still have your stock links, Explorer rear swaybar links are the right length for 5" of lift with one end or the other welded on from the stock links.
97 ZJ Limited, all power V8 AWD (wife's DD)
93 XJ Country 32" TSL Radials, 4.5" Rough Country Lift
91 XJ Laredo 33x15.5 TSL SXs, Homebrew 3" lift
Local to Cincinnati, Ohio? Check out our club!
jfiscus is offline
sway bar link acmech13 XJ Cherokee Technical Forum 5 01-21-2009 02:54 PM
Sway Bar End Link Issue Parky XJ Cherokee Technical Forum 6 03-31-2008 11:13 PM
Sway Bar End Link ??? oj_584 XJ Cherokee Technical Forum 1 04-15-2007 01:38 PM
sway bar link scorch XJ Cherokee Technical Forum 2 03-20-2007 08:50 PM
what length sway bar end link? tarvis XJ Cherokee Technical Forum 1 03-17-2006 04:03 PM
