Lifters ticking LOUDLY and then stopping... - JeepForum.com
post #1 of 8 Old 03-29-2013, 06:41 PM Thread Starter
xosunshineox
On a cold start in 15 degree weather, I would hear my lifters making noise, but it would go away after the car warmed up. This only happened twice. I have a check engine light throwing out codes for the O2 sensor, two misfires, and a lose gas cap. I tried to replace the O2 sensor but didn't have the right size wrench so I put it on hold untill tomorrow.
I started my engine a couple hours after that, and now the lifters are louder then ever and took about 30 minutes to stop making noise. I also had an extremely rough idle and a high oil pressure reading (40 at idle, 80 when accelerating). Usually my oil pressure sits at 15 psi when idle, and 40 when accelerating. Another thing I noticed is that the evap solenoid wasn't making it's usual clicking noise. It was much faster and sporadic.
Is my oil pump bad, or could I possibly fix the lifter noise by using Sea Foam? Also, what would cause the noisy lifters, high oil pressure, and rough idle (similar to the vibrations of a Death Wobble) if I didn't even replace parts or take any off for that matter?
xosunshineox is offline
post #2 of 8 Old 03-29-2013, 08:12 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
What happens if you shut the engine off immediately and wait 30 seconds and restart? Noise gone?
What brand of oil filter are you using?
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #3 of 8 Old 03-30-2013, 07:45 AM
CCKen
CCKen's Avatar
Could be the cam is walking due to bad cam bearings. Hook up a direct reading oil pressure gauge in place of your oil pressure sender and check the oil pressure. See if you get the same readings you see on your instrument cluster oil pressure gauge.
Direct reading oil pressure test sets can be rented (refund) from O'reilly, Advance, or other auto parts stores. Threads on the sender are 1/8" pipe thread. Use a 27 MM deep socket to R&R the sender.
CCKen is offline
post #4 of 8 Old 03-30-2013, 08:12 AM Thread Starter
xosunshineox
Same issues when I restarted, however this morning all symptoms are gone and it's running normal again with the typically oil pressure reading.
I'll look at the oil filter today. I'm not sure which brand it is because when I took the Jeep to be looked over by my mechanic I also had him do an oil change.
I'll check it out today.
post #5 of 8 Old 03-30-2013, 11:41 AM Thread Starter
xosunshineox
Is it possible that my oil is too thick? What kind of oil should I put in it with a problem like this?
Oh, and I couldn't see much of the details on the oil filter. It's an Athena. What kind of oil filter has the most reliable DBV?
post #6 of 8 Old 03-30-2013, 03:20 PM
Timo_90xj
Timo_90xj's Avatar
5W-30 works well, but can be a bit on thick side in extreme cold. I've used 5W-30 or 5W-40 full synthetics on all my Jeeps without any serious issues down to around occasional -20*F days. Lifters could be a bit noisy on initial startup, but goes away in a few minutes.
As suggested check your oil pressure with a direct reading gauge and use high quality oil filters. If oil pressure is normal, I wouldn't worry too much.
***Under construction***
Timo_90xj is offline
post #7 of 8 Old 03-30-2013, 05:33 PM
BIGBADWOLF
Yeah but the problem is most likely a bad lifter that bleeds down. The thick oil when cold will take awhile to re-fill the lifter. A nusinance but no real harm unless lifter fails to pump up at all.
BIGBADWOLF is offline
post #8 of 8 Old 03-30-2013, 06:24 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Just for fun go to Napa and get a Napa Gold filter. Replace it only and see what happens.
