lifted jeep alignment - JeepForum.com
post #1 of 8 Old 12-14-2006, 05:10 PM Thread Starter
BigwillXJ
My dad was recently tapped in the drivers side rear on the highway. His jeep has no marks at all but the wheel took a beating. So he got it aligned and put the bad wheel in the back and got a horrible vibration. So yesterday we got the wheel replaced and everything balanced and we still get the horrible vibration about 50 mph. My ? is there any different secification for alignments for a lifted xj?
The jeep is an 87 with RE 3.5" superflex with non adjustable lowers.
(Totaled)
97 xj sport
4.0L, 5 spd, RE 4.5", AA SYE/TW ds, 32" bfg mud-terrains, borla catback exhaust, 4.56's
NC State
BigwillXJ is offline
post #2 of 8 Old 12-14-2006, 08:21 PM
Arcticcat843
dakuda is a god
Arcticcat843's Avatar
1980 CJ5
Well i would say No just becuase i know they used the stock spec to align my jeep. But i guess it could be wrong on mine to, but i dont have any bad vibrations.
Arcticcat843 is offline
post #3 of 8 Old 12-15-2006, 12:16 AM
XJING
Speed related wobble is 99% of the time related to balance of the wheel and TIRE, sometimes the tire will slip a belt, or if it did get hit in the accident maybe the belts are bent. Try putting the spare on the tire that got hit and see if it makes a difference. Good Luck
Originally Posted by FleXJ the Kid
Yes, probably, I dont know. I could but sometimes it was difficult. Just get under there and try.
XJING is offline
post #4 of 8 Old 12-15-2006, 12:19 AM
mud-dog27
when it comes to jeeps and alignments its pretty much usless cause all you can really do is adjust the toe....i had mine done when i lefted but like 2weeks later it was outta whack again pretty much just check everything that could have been damaged in the front end...and go from there
89 wagoneer LTD. , 32x11.5R15 wild country RVT, 15x8 AR baja rims , surco safari roofrack w/spare tire kit , cobra 19 DXIII w/ high gear mic. 4' whip on a 3" heavy-duty spring , 4.5" rough country full leaf pack lift kit
mud-dog27 is offline
post #5 of 8 Old 12-15-2006, 06:35 AM
XJING
I guess thats why they make adjustable Track bars and adjustable upper and lower control arms. (So you can adjust for castor too)
I have adjusted my castor at 2" lift hight with shims in the control arms and an Adjustable Track bar to bring the axle dead center. Never have a problem with alignment,
XJING is offline
post #6 of 8 Old 12-15-2006, 09:14 AM
Jason, aka: Jeepin.com
Vendor
Jason, aka: Jeepin.com's Avatar
1995 XJ Cherokee
why do people think this? caster is completely adjustable on XJ's, regardless of if you're lifted, or stock, or have adjustable arms or not. The only thing not adjustable on an XJ in stock form is camber. And even that can be adjusted if you get eccentric balljoints.
edit: it's quite possible that the axle got bend, or something else was damaged when your dad's XJ got hit that is causing the vibration.
Jason West -
'16 JKUR Hard Rock, RE/Synergy 3.5", 37" GY MTR/Ks
'95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc.
'00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
Jason, aka: Jeepin.com is offline
post #7 of 8 Old 12-16-2006, 04:10 PM
anony91xj
As usual...start with the basics. Rotate the tires front-to-back and see if the vibration moves to the front. If it does, that tire is the culprit. Even if it's balanced on a balancing machine, that doesn't mean that the belts haven't slipped or that it's worn evenly. Check it out closely, you'll probably have to replace it if the vibration changes with the tire rotation. Check the other 3 tires closely while you're at it.
If the vibration doesn't change, look at the rear axle and driveline. It is possible that the axle shaft got bent in the accident. Is one axle seal leaking badly? That could be a sign of a bent shaft. If this is your issue, I'd recommend heading to the junkyard for a complete rear instead of just replacing the shaft and hoping that'll fix your issue.
Neither of these issues are alignment related, but they are the most likely causes for your vibration.
1998 VW GTI 2.0
anony91xj is offline
post #8 of 8 Old 12-17-2006, 07:53 AM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Just to clarify, the caster adjustment is made via the lower control arm mount. If you look at it, there is a U shaped bracket inside the mount itself. There is a bolt that is attached to that and it goes through the rear of the mount and bolts down.
You adjust the caster by adding shims between the Bracket and the back of the mount and that will push the LCA forward or allow it to be moved back.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
alignment on the jeep jebmccall XJ Cherokee Technical Forum 3 12-13-2009 05:12 PM
How to tell if my jeep is lifted? miniderblank XJ Cherokee Technical Forum 25 12-12-2009 07:17 PM
first lifted jeep codybutz XJ Cherokee Technical Forum 7 11-07-2009 01:46 PM
What would you pay for this lifted Jeep Cherokee? SomerJeep XJ Cherokee Technical Forum 10 07-14-2008 10:42 PM
Just got my jeep! is it lifted??? Tapout XJ Cherokee Technical Forum 15 07-11-2007 01:05 PM
