Lift questions?!?!?? - JeepForum.com
post #1 of 7 Old 07-10-2013, 04:02 PM Thread Starter
clab0603
Hey guys I just started installing my 4.5" Rough Country X-series lift. I got the rear done and put some new shackles that are 2" drop from auto-zone. I am done with the rear. My question is when all said and done will I get away with no SYE needed off the bat. I understand most need it in future but how long can I last without. Also kit comes with a t case drop which should help as well! Please give input in your rides and suggestions! Thanks
clab0603 is offline
post #2 of 7 Old 07-10-2013, 05:10 PM
Floreancig_XJ
Start with what you have(tcasedrop) and you might just be alright at that height. 97+ are more common for vibes but ive seen a 98 at 9.5 and 8.5 actually drive just fine with only the drop, wears out your joints faster
Floreancig_XJ is offline
post #3 of 7 Old 07-10-2013, 05:35 PM Thread Starter
clab0603
Yea that is good idea! Mine is a 96 so hopefully ill be fine. I finished rear and drove down road today and it vibrated like hell! But hopefully that's just because once side is so much higher
clab0603 is offline
post #4 of 7 Old 07-10-2013, 07:48 PM
rugsucka
You will need to drop your crossmember using a spacer kit or install a SYE to avoid driveline vibrations even when you do get the front suspension in.
4 degree shims for your rear axle perches will help point the pinion up at the Tcase where it belongs and that will help quite a bit too, but the slip yoke being pulled out and at a poor angle for 1 Ujoint can only be corrected with a SYE and double cardan driveshaft.
Baseline outfiters sells a complete SYE kit for 150 on sale once in a while and usually around 170. IRO sells a HnT SYE for about 50 less.
A front driveshaft from any automatic XJ will be a good replacement for your rear DS when the SYE is installed.
rugsucka is offline
post #5 of 7 Old 07-11-2013, 03:13 PM
RedRyderXJ
1994 XJ Cherokee
A 8.5 and 9.5" lifts with only a t case drop and no vibes? No way. The driveshaft would fall out, especially if it was articulating the suspension.
RedRyderXJ is offline
post #6 of 7 Old 07-11-2013, 04:08 PM Thread Starter
clab0603
I just pulled back my boot on rear drive shaft and it's pretty far extended I hope it works with t case drop!
clab0603 is offline
post #7 of 7 Old 07-11-2013, 11:14 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
SYE's are required for lifts past 4.5" I would not drive it until you do a SYE
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
