lift problems...help - JeepForum.com
post #1 of 8 Old 09-21-2012, 09:01 PM Thread Starter
01cherokeespot
Hey everyone this is my first post on here ..ive decided to install my rough country 4.5 long arm kit this weekend on my 01 xj and ive started the rear so far and ran into some problems. Ive cleaned the whole underside of my xj and pb blastered it for a week straight. everythings off in the rear except the front leaf bolts. The one i broke loose and and it backed out just about all the way but seems to be stuck on something on the very end. Any one have an idea how i should go about this? the other one i just couldnt budge i dont have any air tools so i was using a 12 inch breaker bar and a piece of pipe so i soaked it again and gonna give it another shot tomorrow. And also the top mounts to the shocks all snapped right off..i heated them up too. Should i try to drill through the and tap them? sorry if these are noob questions this is my first lift, Any help is aprecciated
01cherokeespot is offline
post #2 of 8 Old 09-21-2012, 09:22 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Leaf bolts - For the one that's stuck at the end tighten it some and grind or file the end to bevel at the last thread or two. It may be rolled or whatever and preventing it from coming off. For the one that won't break loose if you can heat the nut to break the rust. Either that or keep doing what you're doing but you run the risk of breakage.
For the shock mount drilling and tapping may be your only option.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #3 of 8 Old 09-21-2012, 10:04 PM Thread Starter
01cherokeespot
thanks i just found a good write up for the shock mounts... but for the leaf bolts if i cut the end off what will the bolt screw into when i put the new leafs on?
post #4 of 8 Old 09-21-2012, 10:07 PM Thread Starter
01cherokeespot
and sorry but what do u exactly mean by rolled?
post #5 of 8 Old 09-21-2012, 11:17 PM
ltrail
1984 XJ Cherokee
I had to cut inside of frame and put new nut/ bolt I'm there. Bolt was rusted and broke tack welds inside. The other was rusted th the bushing sleeve. I believe he means the bushing sleeve could have been squished making the bolt removal difficult.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #6 of 8 Old 09-21-2012, 11:21 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
I think it's a TJ thing, you can't do what he said on an XJ.
Knock those shock bolts out of the holes and use new ones.
***Chris***
chris87xj is offline
post #7 of 8 Old 09-22-2012, 03:54 PM
JerpXJ
The front leaf bolts may be stuck in the metal collar in the bushings, thats what mine did, I had to cut the leaf springs off, the cut away the bushings and got to the collar with a cuttoff wheel, cut a slit in them then pry them away until they come off, then the bolt comes right out. And if your rough country leaf packs are like mine you are going to need a bottle jack and some patience to get them into place.
JerpXJ is offline
post #8 of 8 Old 09-22-2012, 06:27 PM Thread Starter
01cherokeespot
Thanks every one i got the one out by pryin on it really hard with another person and spinning it out...the other one i cut off on both side of the leaf and got it to come..i went to the chrysler dealership and got two new bolts so they went in fine...and putting the new leafs on was fairly easy i pushed the shackle all the way forward because from what i heard thats how it makes ur schackle angle anyway and just jacked the differential up with a floor jack. I lubed everything up in the front again and and will doing that tomorrow..thanks again
bolt failure , broke , leaf , rough country long arm , shock mount
lift problems... help!!! nessbran XJ/MJ Cherokee Non-Technical Forum 5 07-30-2011 02:22 PM
Problems After Lift collkid XJ Cherokee Technical Forum 12 11-24-2008 11:36 PM
HELP!! Problems during the lift! ReconMill XJ Cherokee Technical Forum 18 08-19-2007 04:39 PM
lift problems BigwillXJ XJ Cherokee Technical Forum 1 11-11-2005 02:17 PM
Mid lift problems SpikeSpeigel XJ Cherokee Technical Forum 6 07-11-2005 02:47 PM
