Lift kit advice needed! - JeepForum.com
post #1 of 9 Old 07-24-2012, 08:39 AM Thread Starter
DannyBoy845
DannyBoy845 is offline
post #2 of 9 Old 07-24-2012, 08:41 AM
Bbasso
The best advice I got was to keep reading/learning.
I just went through this at the beginning of the month.
Bbasso is offline
post #3 of 9 Old 07-24-2012, 08:49 AM
pokeyxj
I'm running a Rusty's 4.5 all spring lift on my 00 XJ. The kit came with front and rear springs, rear spring shim to tilt the pinon up, longer lower control arms, front sway bar extension brackets. I have not had any issues with 265/75/16 BFG MT KM2 tires. (thats about 32.4 inch tall) Definately research your options though and decide what you want and need.
2000 XJ Limited, 4.5 Rusty's All spring lift; 265/75/16 BFG KM2's; 4.0, aw4, 242.
2001 XJ Sport, 4.5 Rusty's lift, 32x1150x15 Hankook Dynapro MT's. 4.0, aw4, 231, 8.25 rear with power trax locker.
08 f 150 2.5 lift, 33's, arb.
pokeyxj is offline
post #4 of 9 Old 07-24-2012, 09:05 AM
Motorcharge
There are stickies and FAQs at the top of the page for a reason.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #5 of 9 Old 07-24-2012, 09:51 AM
DaveS01
Such a general question. Searching would return what your asking.. anyways. You'll need leaf packs (don't go aal) coils, shocks, id recommend a new trac bar, you'll need new lcas, possibly a tc drop or a sye. Im at 4.5 with neither...but the yoke on my dana 44 is longer, and I have shims, so both help drive line angles. You could buy 3.5 packs and then add a shackle for better flex...or relocation brackets. If I were you id piece a lift together. Buy RE coils and leafs from seriousoffroad, get some shocks (whatever you can afford, if you have the cash to drop buy bilsteins), get some lcas from rustys or anyone really, if you want to go big get a double sheer trac bar. Install everything, see if you have vibes and go from there.
DaveS01 is offline
post #6 of 9 Old 07-24-2012, 10:55 AM Thread Starter
DannyBoy845
Thanks alot man
post #7 of 9 Old 07-24-2012, 12:04 PM
DaveS01
Originally Posted by DannyBoy845
Thanks alot man
Not a problem
DaveS01 is offline
post #8 of 9 Old 07-24-2012, 12:13 PM
buildin1XJ
DannyBoy gave you some pretty good advice,I would do the adjustable Trac Bar and SYE if you can afford to do so.
buildin1XJ is offline
post #9 of 9 Old 07-24-2012, 12:45 PM
DaveS01
Dannyboy is the one asking the ?s
DaveS01 is offline
cherokee , lift kit , xj
Suspension lift advice needed waynej20 XJ Cherokee Technical Forum 15 06-22-2012 12:17 PM
advice needed: do I buy it? mnrsxs XJ/MJ Cherokee Non-Technical Forum 7 03-18-2009 03:10 PM
Lift Kit questions and advice needed CheyenneK5 XJ Cherokee Technical Forum 5 02-03-2009 09:03 PM
DAMN! Lift ADVICE needed. ...("1-"3) 4.0H.O.XJ XJ Cherokee Technical Forum 12 12-28-2006 05:48 PM
Advice Needed bmyohn XJ Cherokee Technical Forum 6 11-26-2006 04:50 PM
