lift installation cost? - JeepForum.com
post #1 of 15 Old 08-07-2005, 07:34 PM Thread Starter
moclov49
hello everyone i was just wondering what kind of prices you guys are paying to get your lift kits installed, of course many of you install them yourselves and if so how difficult do you think it would be to install a 4.5" rusty's lift myself?
thank you.
moclov49 is offline
post #2 of 15 Old 08-07-2005, 07:38 PM
kairo
kairo's Avatar
i'll let everyone else say it better, but, do it yourself It's not that hard, just time consuming
Was: 1979 CJ-5, 1982 CJ-7, 1995 XJ, 1991 YJ, 2006 KJ, 1979 F-150
Is: 2011 Ram 1500 Hemi & '02 TJ on 35's
kairo is offline
post #3 of 15 Old 08-07-2005, 08:07 PM
xj89
yea, you can do it yourself, you will have more pride in it, also take the money you would spend to have a shop install it and spend that money on new tools. Your best friend for the install shall be, PB Blaster, an oxy map torch( 50 bucks at home depot) a huge breaker bar, and a lot of time. you can do it. 90% of the guys here have and im sure if theres anybody on this site in your area a lot of ppl on here would be willing to help for a case of beer
74 CJ5
86 CJ7
89 Cherokee
xj89 is offline
post #4 of 15 Old 08-07-2005, 08:32 PM
conrasm
conrasm's Avatar
Stopped at a local 4x4 specialty shop before I decided on a lift just to get an idea. They wanted ~$400 for installation on a Rubicon Express 3.5" lift which is roughly the same amount of parts as a Rusty's 4.5" lift. I did mine with some help from my dad and some friends. If you attempt it, definetly get the MAPP gas (you can hold it as any angle. It's not a liquid like propane) to heat up those hard to loosen bolts, a saw zall (you can rent those) incase you have to cut your rear leaf bolts if they rust to the shackle bushings, and plenty of penetrating oil (PB blaster) and spray daily for a week before you start. Lifts look easy to put on, but suspension bolts end up rusty and can be hell to get loose. Plus you would need some extra hands and jacks/jack stands to work with the axles.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
post #5 of 15 Old 08-07-2005, 08:57 PM
Silver TeeJay
Silver TeeJay's Avatar
Well it was not worth the 2-3 days effort in my case - that's what it would have taken me LOL!
So the $300.00 I spent was WELLLLLLLLLLLLLLLLLLLLLLLLL worth it plus they had the Jeep for only 6 hrs - That was due to the wrong size shocks being delivered.
2005 Jeep TJ "RME" - Bright Silver Metalllic - 4.0 Auto
2" BDS Coil Spacers / BDS Steering Stabilizer / BDS 5500 CAV Shocks / JKS 1.25" BL / JKS 1" BMML / Dana 44 / 3.73 Gears / Custom Rock Sliders / 32x11.50 BFG KO's / 15x8 AR Diamond Backs
Proud member of the KC Jeep Club!
Silver TeeJay is offline
post #6 of 15 Old 08-07-2005, 09:07 PM
blakdot
blakdot's Avatar
Do it yourself... when me and my friend installed his 3" and neither of us had ever put it a lift before. It took us all night to do but we did it without to many snags along the way. Plus bragging rights to your friends is best if you can say you did it yourself.
His:
'85 CJ-7
'87 Cherokee Laredo
Hers:
'00 Cherokee Sport
-Matt-
blakdot is offline
post #7 of 15 Old 08-07-2005, 09:10 PM
cherokee xj
$40 bucks for two friends who are experienced lift putter oners (ones a mechanic) who chipped in many jack stands and alot of advice and help. I payed them because i felt bad making them put on my lift for free. It did take a couple days to be completely finished because of PITA broken rear shock mounts. The actual lift itself aside from rear shocks took about 8 hours with MANY wendy's breaks.
stock 2000 Cherokee Sport
black 4 dr.
cherokee xj is offline
post #8 of 15 Old 08-07-2005, 09:11 PM
conrasm
conrasm's Avatar
It took me almost 4 days (weather was not cooperating) to do everything, but I also had some snags along the way. Had to replace rear brake lines on the axle and wheel cylinders b/c the bleeders broke off when I was bleeding the lines. I got a lolnger rear brake hose.
Shawn
conrasm is offline
post #9 of 15 Old 08-07-2005, 09:15 PM
prior2
i just finished mine today, and i must say, what a pain in the ***.... but it was well worth it. i put the RE 3.5" kit on mine, and it took about 16 or so hours over 2 days. all you really need to know is all basic knowledge, it just takes a long time. and be careful w/ the back brakes especially...
prior2 is offline
post #10 of 15 Old 08-07-2005, 09:31 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
It cost me $12.00 to install my Lift but thats a Case of beer to split between me and my Buddy. When me and my Buddy installed his 4.5in Rustys it Cost him $12.00 for Beer and a G/f but she was a -=-=-=-= anyway
it took us about 4hrs to to our lifts but we had a Lift to use and Airtools
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #11 of 15 Old 08-07-2005, 09:35 PM
WhtJeep
2008 WK
It took me 3 hours to do my 3" lift. No broken bolts, no broken shock mounts, nothing bad happened. But just hit up some of your friends, that what i did. Works better.
2008 WK Khaki Grand Cherokee Rocky Mountain
1995 XJ Lifted and driven straight into the ground - RIP
Originally Posted by cresso
Quick dana 35 test: kick one of the rear tires. If the axle breaks, it's a 35
XboxGT - The Mad Med1c
WhtJeep is offline
post #12 of 15 Old 08-07-2005, 10:05 PM
cvsahara
Its not hard to do yourself. I just installed the 4.5" rustys lift last weekend. It took me and one other guy about 6 hours to do it all and put on rusty's drop crossmember and transfer skid.
a few things that are a must is a good vehicle jack, at least 2 jack stands, full compliment of sockets, ratchets and wrenches.
we had to use a come along to get the axle in position to put the second LCA into the proper position.
also, the instructions that come with the kit are short and quite vague but there is a decent write up on rusty's site.
97 TJ 35's, 4.88's, Arb in front, detroit in rear
84 CJ stock
cvsahara is offline
post #13 of 15 Old 08-07-2005, 10:06 PM
copbait
I just did a 2" BB by myself (coil spacer w/ AAL), took me two days (about 12 hrs), but I had no suspension experience at all and had to make _several_ tool runs. It was a real *****, but it was mostly fun and VERY educational, definitely worthwhile to do it yourself if you have the time.
copbait is offline
post #14 of 15 Old 08-07-2005, 10:07 PM
Brandon11130
install it yourself, you will be better off, you will have a better understanding of your suspention and if somthing breaks on the trail/highway you know how to fix it(or at least know how to take it off) it will be a learning experience. basically its just you jacking up your xj unscrewing some bolts and bolting it back together
1959 JEEP CJ5
We do not ask for your poor or your hungry. We do not want your tired and sick. It is your corrupt we claim. It is your evil that will be saught by us. With every breath we shall hunt them down. Each day we will spill their blood ‘til it rains down from the skies.
Brandon11130 is offline
post #15 of 15 Old 08-07-2005, 10:41 PM
prior2
i couple good tools if you have it are a drill, w/ set of drill bits, and maybe some easy outs if one of your upper shock mount bolt breaks in the rear... and an air compressor w/ some air toold such as an impact gun and air ratchet help a lot too...
prior2 is offline
Cost of lift cherokee99spt XJ Cherokee Technical Forum 8 10-16-2006 09:44 PM
Installation Cost nevaquit01 XJ Cherokee Technical Forum 3 03-20-2006 10:41 PM
Total 5.5 Lift cost Scotch740 XJ Cherokee Technical Forum 11 03-11-2005 10:34 PM
How much does it usually cost to have a lift installed? Dannyboy18 XJ Cherokee Technical Forum 16 01-21-2005 10:33 AM
Cost of lift? JoshP XJ Cherokee Technical Forum 10 05-02-2003 02:32 PM
