Quantcast Length for 4" lift shocks... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Length for 4" lift shocks...
Old 04-11-2009, 09:47 PM   #1
94HOCHEROKEE
1994 XJ Cherokee
Been searching with no luck....... What is the best length for a 1994 cherokee with a 4" lift??? any help is greatly appreciated
94HOCHEROKEE is offline   Reply With Quote
Old 04-11-2009, 10:11 PM   #2
CJ7-Tim
Go Jeepin
CJ7-Tim's Avatar
The place selling you the shocks should know the answer to that question or else you should buy your shocks from a more knowledgeable seller.
To measure for your shock lengths, flex your suspension with no shocks installed and measure the distance between the shock mounts with the suspension full compressed, and fully extended. The measurements you take are used to determine the shock lengths needed for your lift. Choose your shocks, and then locate the shock specifications chart that most shock manufacturers publish or list on their website.
When measuring flex, make sure you have the correct bump stop length for your lift installed. Bump stops prevent contact between the tires and fenders, and prevent shock damage from bottoming out the shocks compression stroke.
You can use the chart below to find the approximate shock dimensions needed based on lift height.
Shock Lengths
Front Shocks = Bottom Eyelet With Top Stud Mount
Rear Shocks = Bottom/Top Eyelet Mount
Brand/Model # Extended Collapsed Travel Position
Monroe 32252 (* Stock) 21.25 13 8.1 Front
Monroe 37193 (* 1-3 “ Lift) 24.25 13.37 10.8 Front
Monroe 911524 (* UpCountry) 21.00 13.4 7.6 Front
Doetsch DT3350 ( 3-5” Lift) 26.5 15.5 11.0 Front
ES1000 ES124515 (* 3" Lift) 24.50 14.38 10.0 Front
ES1000 ES121515 (* 0-2" Lift) 21.52 12.72 8.8 Front
ES3000 ES324515 (* 3" Lift) 24.70 14.52 10.2 Front
ES3000 ES321515 (* 0-2" Lift) 20.24 12.45 7.8 Front
ES9000 ES921515 (* 0-2" Lift) 21.75 13.06 8.6 Front
ES9000 ES924515 (* 3" Lift) 24.70 14.52 10.2 Front
Skyjacker SJA-H7016 (* 1-3" Lift) 22.75 13.54 9.2 Front
Skyjacker SJA-H7025 (* 3-5" Lift) 24.75 14.54 10.2 Front
Skyjacker SJA-N8016 (* 1-3" Lift) 22.75 13.54 9.2 Front
Skyjacker SJA-N8025 (* 3-5" Lift) 24.75 14.54 10.2 Front
Skyjacker SJA-M9016 (* 1-3" Lift) 22.75 13.54 9.2 Front
Rancho RS5239 (* 3" Lift) 23.75 14.37 9.38 Front
Rancho RS5128 (* Stock) 20.87 13.00 7.8 Front
Rancho RS99239 (* 3" Lift) 23.75 14.37 9.38 Front
Rancho RS99128 (* Stock) 20.87 13.00 7.8 Front
Rancho RSX17317 (* 3" Lift) 23.75 14.50 9.25 Front
Rancho RSX13036 (* Stock) 20.50 12.87 7.6 Front
Bilstein F4-B46-1798 (Stock+Upcountry) 21.50 13.25 8.25 Front
Bilstein F4-BE5-6241-H8 (4” Lift)……………………………………….………….Front
Brand/Model # Extended Collasped Travel Position
Monroe 32269 (* Stock) 21.50 13.37 8.1 Rear
Monroe 37194 (* Upcountry) 21.12 13.87 7.2 Rear
Monroe 911525 (* Upcountry) 21.50 13.87 7.2 Rear
Monroe 37029 (1-3” Lift ) 23.00 14.375 8.6 Rear
Superlift SLF-85112 (* 2-4" Lift) 24.00 14.50 10 Rear
Superlift SLF-84140 (* 3-5" Lift) 26.07 15.57 10.5 Rear
Superlift SLF-85080 (* 0-2" Lift) 21.57 13.32 8.25 Rear
ES1000 ES124509 (* 3" Lift) 24.86 14.84 10 Rear
ES1000 ES121515 (* 0-2" Lift) 21.52 12.97 8.5 Rear
ES3000 ES324509 (* 3" Lift) 24.84 14.82 10 Rear
ES3000 ES322509 (* 0-2" Lift) 22.58 13.71 8.8 Rear
ES9000 ES922509 (* 0-2" Lift) 22.58 13.72 8.8 Rear
ES9000 ES924509 (* 3" Lift) 24.84 14.82 10 Rear
Skyjacker SJA-N8058 (* 3-5" Lift) 24.84 14.82 10 Rear
Skyjacker SKA-H7058 (* 3-5" Lift) 24.84 14.82 10 Rear
Doetsch DT-3000 3265 (* 4" Lift) 24.50 14.50 10 Rear
Doetsch DT-3000 3268 (* 2" Lift) 22.50 13.50 10 Rear
Doetsch DT-8000 8265 (* 4" Lift) 24.50 14.50 10 Rear
Rancho RS5194 (* 2-3" Lift) 23.25 14.37 8.8 Rear
Rancho RS5259 (* Stock) 21.50 13.50 8 Rear
Rancho RSX13037 (* 0-2" Lift) 21.12 13.50 7.62 Rear
Bilstien F4-B46-1799 (Stock+UpCountry) 21.50 13.25 8.25 Rear
Bilstein F4-BE5-6686-H6 (4” Lift) …………………………………………….Rear
Note: * These lift heights were included where the shock lengths were found. These were the suggested shocks for that amount of lift. I have no way to ensure these are accurate.
If this info has been helpful, please click on the "Thumbs Up" icon.
FOR SALE: Wide Track CJ-7 Dana 44 rear axle.
PM me for details
A Government big enough to give you everything you want, is a Government big enough to take from you
everything you have. The course of history shows that as a Government grows, Liberty decreases.
CJ7-Tim is offline   Reply With Quote
Glock Forum
