left turn signal doesn't work if braking - JeepForum.com
post #1 of 7 Old 12-27-2010, 12:22 AM Thread Starter
jennali
Hi. I have a 2001 XJ that I bought about two months ago. The problem is that when I am braking before I turn, the left turn signal stops blinking (light on dash stays lit), but as soon as I take my foot off the brake it blinks normally. Just before it did this the left turn signal was blinking quickly like it would if a bulb was out, and the right turn signal works fine. On a side note, my left rear tail light is burnt out (I assume it is since it isn't lighting, although the brake lights are fine), and I have only really had this issue since the weather got colder. Any ideas? I saw some similar threads on here but nothing quite answered my question. Any help is greatly appreciated!
jennali is offline
post #2 of 7 Old 12-27-2010, 01:36 AM
littlehoov
1986 XJ Cherokee
It sounds like a ground issue...Id pop off the taillamp assembly, look for any poor connections, melted connections, etc.
I believe the ground for the turn signals is underneath the plastic piece on the side of your rear cargo area, theres probably also an adapter plug there worth checking out.
My moms Venture had similar problem which was caused by the ground plug on the plastic taillight connector melting...a common problem in those vans.
1986 Cherokee 2.8 V6, Torqueflight 904 transmission, NP-228 transfer case. 235/75/15 AT tires. Factory tow hooks...thats about it.
littlehoov is offline
post #3 of 7 Old 12-27-2010, 02:15 AM
Mr_Clickerson
1994 XJ Cherokee
Seconded. Sounds like a bad ground. Had the same issue with my blinkers when my headlights were on. Bad grounds to the parking lamps just below the headlights.
Originally Posted by Lamb of God
Whoever appeals to the law against his fellow man is either a fool or a coward; whoever cannot take care of himself without that law is both. For wounded man shall say to his assailant, "if I live, I will kill you- if I die, you are forgiven;" such as the rule of honor.
Mr_Clickerson is offline
post #4 of 7 Old 12-27-2010, 08:25 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I would start with replacing the bulb and see if the issue goes away. Sometimes the bulb will cause the problem, also make sure the socket is clean and rust/dirt free. Then add a small amount of dielectric grease to the socket before putting the new bulb in. If the bulb doesn't fix it then the above posts are correct that it is a ground problem. More often than not the ground issue is within the socket rather than the wiring though.
xjfever is offline
post #5 of 7 Old 12-27-2010, 06:06 PM Thread Starter
jennali
Thanks for all the advice! It's freezing cold and dark out now and my jeep lives outside but tomorrow I will try to replace the bulb and if it's still messed up I'll look at the grounding...I don't know a ton about cars but I would love to fix this myself and not pay a ridiculous amount of money if it is a relatively simple problem...I'll keep you posted and may ask more questions later! Thanks
jennali is offline
post #6 of 7 Old 12-27-2010, 06:56 PM Thread Starter
jennali
Ok well I tried to post a reply about an hour ago but it is not showing up so I will try again! Thanks for all of the advice first off. It is dark out and freezing cold now and my poor little jeepie lives outside but tomorrow I will try to replace the taillight and see if that helps at all. If not then I will try to look at the grounds. I don't know a ton about cars but I would love to try fix this myself and not spend a ridiculous amount of $ on a relatively simple problem. Also I forgot to mention that I do have a trailer hitch (which I will be removing at some point). Could that be affecting the lights where it is wired in? Also, when i put my hazard lights on, ONLY my left turn signal flashes, my right does not....very bizarre to me. Thanks again and I will probably be back with more questions tomorrow!
jennali is offline
post #7 of 7 Old 12-27-2010, 07:55 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
You can fix it yourself with a little help, and there are a ton of folks here who can help you. Just post up your results and if you don't get it fixed right away someone on here will help you through it. The trailer wiring could also be the culprit, but it for sure sounds like a ground problem. Good luck and welcome to the forum.
xjfever is offline
brake , turn signal , xj
left rear tails do not work--left signal and left stop do- kenific XJ Cherokee Technical Forum 2 12-06-2008 01:23 PM
Left Turn Signal Going Crazy Redrum8675 XJ Cherokee Technical Forum 7 09-08-2008 03:10 PM
Left turn signal ledfoot02 XJ Cherokee Technical Forum 1 12-25-2007 09:05 AM
Left turn signal wont turn off. paulmatyn XJ Cherokee Technical Forum 13 12-15-2007 12:38 AM
right turn signal faster then the left vswv8 XJ Cherokee Technical Forum 7 10-06-2007 10:27 AM
