LED light installation question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > LED light installation question
Steering and more from Ruffstuff!Ruffstuff Axle Simple Swap Kit!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 05-25-2015, 09:10 PM   #1
xjken99
I am installing a couple 4 inch cube led lights under my front bumper. They seem to flicker a little when they are on with the Jeep running. When I turn the lights on with the Jeep not running the passenger side light does not light at all. The light brackets are solidly mounted to the metal bumper and the system is securely grounded. Also the power wire is securely attached to the battery. Any idea what I am missing?
Just a slightly modded XJ with a little lift, some armor, four mud tires and a few decals, so far.
xjken99 is offline   Reply With Quote Quick reply to this message
Unread 05-26-2015, 05:31 AM   #2
wizardPC
Check the voltage. When I installed my rear cube lights I was getting barely 10v,which was the absolute minimum required for the lights to turn on.
Also double check your connections.
http://GunsCarsTech.com
If I've never pissed you off, give it time.
wizardPC is offline   Reply With Quote Quick reply to this message
