Led dash lights...specs? - JeepForum.com
post #1 of 11 Old 05-19-2013, 10:45 AM Thread Starter
cmarshall21
1997 XJ Cherokee
I really like the cheap little mods I have seen people do where they change the color of their dash lights. I'm looking to do this in my XJ 97' to green but cant seem to find the specs for the bulbs.
Does anyone happen to know the specs ow where I can find the specs?
I hope its as simple as taking out the old bulbs and replacing the with the new led ones I get. If not does anyone have any tips? or Have done this mod?
cmarshall21 is offline
post #2 of 11 Old 05-19-2013, 03:33 PM
Paradise XJ
1988 MJ Comanche
Just an FYI on the lighting. If you go ahead and put LED's in the dash cluster, don't put LED's in the blinker and hi-beam sockets. Those light shine directly straight at you and are somewhat blinding when driving at night. Just sayin'.
I did this and swapped the regular bulbs back in after a couple days. I still have LED's in all the other slots. I got my white faces and LED's on eBay.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #3 of 11 Old 05-19-2013, 03:53 PM Thread Starter
cmarshall21
1997 XJ Cherokee
Do you happen to still have the specs or pics of how yours came out?
post #4 of 11 Old 05-19-2013, 04:38 PM
Motorcharge
T5 wedge base
194s for the dash, shifters, glovebox ect
74s for the HVAC
Don't quote me on it, but iirc the dash takes 5, glovebox 1, and one for each shifter. 3 for the HVAC.
I have all of mine swapped out and have no problems with the brightness on any of them, though on the older style dashes it's area lit rather than backlit so I dunno how bad it is on 97+.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #5 of 11 Old 05-20-2013, 08:49 AM
tim111762
Super easy project and worth the $15. I went blue LED and was happy with how they turned out. The only problem I had was a slight hot spot with the diff shifter. Not a big deal tho
tim111762 is offline
post #6 of 11 Old 05-20-2013, 09:20 AM
chriskeenan
the cluster takes five #74s for the back lighting, all the other cluster bulbs are also #74s. 194s for the shifters, and neo5s or neo4s for the hvac and switches.
The hvac is kind of a waste of time though, it doesn't shine through very well.
You can use white paper in the shifters to eliminate hot spots.
chriskeenan is offline
post #7 of 11 Old 05-20-2013, 04:59 PM
sAe23
1995 XJ Cherokee
Originally Posted by cmarshall21 View Post
[snip]
Just a note: After removing the stock bulbs, the contacts in the sockets may need to be tightened up to keep the LED in place. I used needle nose pliers on mine.
I know the cluster in a 97 is different than a 95, but installing LEDs was possibly the single best upgrade I've done
sAe23 is offline
post #8 of 11 Old 05-20-2013, 11:05 PM
Azzy
Another note, the stock 97 cluster, the blue-green tint is built into the background of the gauge. There are ways around it, one of which is to find an older TJ cluster (they are white behind.. but missing some of the lights). You can try overpowering it with enough light that it barely effects it, or you can try one of a few different kits. (Full disclosure, one of which I make)
The stock panel you have is similar to this, although this is the dummy light version.
If you are doing the LED conversion, I recommend getting ones that are rated for 9-14V, and have a heat sink. They will last the longest. They wont be cheap either.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #9 of 11 Old 05-21-2013, 05:15 PM
chriskeenan
Do you have a link to these? Never seen ones like that.
post #10 of 11 Old 05-21-2013, 05:37 PM
Azzy
I do somewhere.... Let me look.
Aha! it was in my email.
http://autolumination.com/194.htm
Low airflow, and variable voltage (dimming) don't lead to long LED life. Im on my 3rd set, and started to replace the ones I have with standard bulbs.
Azzy is offline
post #11 of 11 Old 05-24-2013, 04:30 PM
JWELK
Google "light condoms" These are colored balloon like items that fit over lamps. Suitably colored "Sharpie" indelible markers work quite well.
Regards,
Jim W
JWELK is offline
dash lights , dashboard , LED lights
