LED Conversion Tips Needed - Page 8 - JeepForum.com
post #106 of 110 Old 02-16-2011, 06:29 PM
Shanker67
yeah the shifter has white paper in it, about 2 pieces, i dont mind how bright it is, but the TC needs cleaned up, thats just bone stock, i must have scratched it by accident when i had it apart
Shanker67 is offline
post #107 of 110 Old 02-23-2011, 07:34 PM
ChrkeeplainsMen
How do you get better lighting on the HVAC {the red side} mines real dim.
2000 XJ 4.5+ Lift 32 BFG AT
2002 F250 7.3Power Stroke 2 Inch Lift 33's DC Bead Lock Black
2007 Yukon Denali Black
ChrkeeplainsMen is offline
post #108 of 110 Old 11-20-2012, 05:43 PM
NJXJ91
Anybody know what bulb the rear liscence plate takes?
NJXJ91 is offline
post #109 of 110 Old 11-22-2012, 06:49 PM
jeffb1113
The bulb type is W5W.
jeffb1113 is offline
post #110 of 110 Old 12-02-2015, 08:43 PM Thread Starter
trevsbmw
Did an LED conversion on my dash about 3 years ago and recently two bulbs went out. Ordered two new bulbs and the didn't work. Turns out the LED's fried something on the circuit board so I'm SOL. This happen to anyone else?
1999 2 Door Cherokee SE w/ 4.0L I-6. Automatic. APN Header, Hooker Aero Chamber Muffler. Hella H4 Euro Headlights w/ Hella Xenon Bulbs, Eautoworks.com wiring harness, Heated Seats
trevsbmw is offline
pinoin seal and bearing tips needed srhcherokee24 XJ Cherokee Technical Forum 25 02-09-2010 04:35 PM
4WD conversion info needed Sdenzik XJ Cherokee Technical Forum 1 01-20-2010 11:05 PM
Parts needed for composite rotor conversion on a 99 nexus42i XJ Cherokee Technical Forum 0 01-25-2009 06:48 PM
Info needed on abs- to non- abs conversion etc.. Timo_90xj XJ Cherokee Technical Forum 5 06-25-2006 12:35 AM
Tips for closed radiator conversion... cyberbackpacker XJ Cherokee Technical Forum 1 08-26-2004 02:46 PM
